Vegas Video discussions from 2005 (Q1Q2) - Page 115 at DVinfo.net
Old May 30th, 2005, 08:19 PM   #1711
Sponsor: JET DV
Vegas doesn't "read" AC3 audio. You'll need to use some other program to convert the audio back to WAV.
Edward Troxel is offline
Old June 2nd, 2005, 04:06 AM   #1712
Gottcha!
It was my PCI IDE Controller, that is probably dying on me right now...
It's the Silicon Image 6080... I am looking into buying a Promise Controller now...
Cu, Matthias
www.mattzi.de
Mathiu Zimmermann is offline
Old June 2nd, 2005, 12:40 PM   #1713
You're welcome!
Good luck.
Dennis
Dennis Vogel is offline
Old June 2nd, 2005, 12:52 PM   #1714
Originally Posted by Matt Ockenfels
In drop frame video, Every frame :00 & :01 are dropped for each minute change except for minutes with 0’s (00:, 10:, 20:, 30:, 40: & 50:)
My understanding of drop frame is that it is frame numbers that are dropped to stay in sync NOT actual frames. Here's one reference: http://teched.vt.edu/gcc/HTML/Virtua...reTimecode.pdf.
Good luck.
Dennis
Old June 2nd, 2005, 12:55 PM   #1715
Are you saying this cam does not use the standard Firewire drivers built into Windows? Virtually every other cam on the market uses these drivers. What is it about the FX1 that requires special Firewire drivers?
Good luck.
Dennis
Old June 3rd, 2005, 03:36 AM   #1716
RED Code Chef
The firewire part is not the problem. The interface to the application seems
to be the issue. The driver needing to be installed is the DVCR driver.
My guess would be that the DVCR drivers understands MPEG-2 (ie HDV!!),
whereas the normal DV driver (from Microsoft and others) only understands
plain DV (DCT based compression, other than MPEG-2).
Such incompatabilities are to be expected with such "new" equipment. What
really is going on is probably only answerable by the folk at Sony & Microsoft.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old June 3rd, 2005, 12:20 PM   #1717
Need Advise for DVI Preview Freezes
The nested projects and DVI previewing are amazing features that led me to upgrade to 6, but I am having a little problem with regular freezing while using the DVI preview window. I wrote the Sony (Sonic Foundry) engineers about the problem, but (so far) they're still working on it. You guys have been extremely helpful in the past, and I though someone might know what's causing this.
System:
P4 2.8 GHz 800 FSB
1 Gb RAM
4 RAID Array Drives (1 RAID 0 & 1 RAID 1)
Matrox P750 Dual DVI 8X Video Card
2 DVI Monitors
other incidental stuff...
Brad
Brad Higerd is offline
Old June 3rd, 2005, 02:45 PM   #1718
I noticed slight jerkiness (but not freezes) during 2nd monitor full screen preview. I guess that is because all frames are recompressed, and CPU is getting overloaded.
Your system specs are aprox. as mine except I overclocked 2.8GHz to 3.07GHz.
Check processes that are running for CPU usage during preview process, might give you a hint.
Andriy Zolotoiy is offline
Old June 3rd, 2005, 03:48 PM   #1719
Using the "Windows secondary monitor"?? - A Preview without Firewire
I have a dream!
I dream of connecting my SVHS PC output to my TV watching the Vegas Preview fly by...
If I read it correctly in the manual and online help, there should be a way to select the "Windows secondary monitor" as preview device. Actually I have selected it as preview device, it just does not preview.
Now as I searched the forum I was only able to find fellow believers working with firewire decks/cameras and converters. My question: What is it with the secondary monitor option in Vegas?
Thank you very much!
Matthias
PS: My TV shows up in the Windows graphics tab as secondary monitor, it is also recognized on pushing "identify displays", only the "details" area shows a "Device unavailable" message..
www.mattzi.de
Old June 3rd, 2005, 07:41 PM   #1720
MSSQL$SONY_MEDIAMGR message
When I open Vegas 6, I get an error message that says MSSQL$SONY_MEDIAMGR service does not exist. The media manager then does not work. Does anyone know what I can do to fix this?
Stephen Sobel is offline
Old June 3rd, 2005, 08:02 PM   #1721
The same happened to me. I can tell you that it happened after I installed the trial of Adobe After Effects and went away after I uninstalled it. I feel that there is a conflict issue.
I also had a similar problem with media manager that had other weird symptoms. An uninstall/reinstall was needed.
It happens with V6.
Do not worry.
DJ Kinney is offline
Old June 3rd, 2005, 08:38 PM   #1722
Sponsor: JET DV
Try the tips listed here:
http://www.sonymediasoftware.com/for...ssageID=389571
Old June 3rd, 2005, 09:20 PM   #1723
Best Way to Crush Blacks?
I had been using the "levels" to crush the blacks, but I recently realized that it kills SO much detail and leaves everything muddy. The effect (minus loss of detail) was really good, though. It was really approaching a filmic level composition.
So what is the best way to do this in vegas?
DJ
Old June 4th, 2005, 01:32 AM   #1724
use the colour curves :)
Peter Jefferson is offline
Old June 4th, 2005, 03:54 AM   #1725
The problem is because of impossibility of uninstalling or reinstalling Vegas trial. I had the same problem and deleted it manualy, now I use Vegas 5.0d and I see that there are many options remained from v6.0b...
Plamen Petrov is offline
