Vegas Video discussions from 2005 (Q1Q2) - Page 11 at DVinfo.net
Old January 14th, 2005, 07:27 AM   #151
ive had 3 HDD's fail with Vegas due to copious amounts of rendering.. ive lost 500+ hours worth of work and now im in teh process of recapturing those tapes (lucky i keep my vidcap files..) so hopfully i can reproduce these projects some time..
Vegas is VERY tough on drives.. more so than any other NLE...
Peter Jefferson is offline
Old January 14th, 2005, 07:30 AM   #152
install DVDA and register from another machine..
launch the HTML on the instaled system
ive had many people call for support on this one....
Old January 14th, 2005, 07:42 AM   #153
this was posted ages ago, you shoulda asked me this when i saw u man!!
One thing about the ram render is that it can cause problems. Its a known issue with newmagic (distributor of VEgas in Aus.. )
anyways... right now, with 1gb ram, u have 895mb to spare for ur ram render..
BUT if u set it full ball, u may inadvertantly kill off ur pagefile allocation as ur ram render cache is higher than ur allocated pagefile for vegas.. then u get stack dump errors during rendering..
ideally for 1gb, 520mb will offer a stable render.. i used to get HEAPS of crashes and wasted alot of time not knowing what the problem was until i took the time to track my pagefile activity....
1gb, drop it to 520 ish.. 2 gb, 1gb ram render should be ok...
im waiting for a render to finsih now, hence the multitude of posts.
Old January 14th, 2005, 08:01 AM   #154
I solved the problem quickly by downloading the newest version from sony.
Chris Moore is offline
Old January 14th, 2005, 09:03 AM   #155
Intermittent problem outputting to external monitor...
I've been experience difficulties getting an image outputting to external monitor recently. I'm actually editing PAL footage for once so I don't know if that has anything to do with it.
FYI: I'm outputting to Sony PVM 14 L5/1 production monitor, via a DSR-11 deck (switch to PAL mode).
I have everything up and running my footage on the timeline and I hit the "preview to external monitor button" and get nothing. So I turn the button off- then try again. Nothing again. I go and change the output setting to "Draft (auto)" and try a third time...nothing for about 5 seconds then FINALLY get an image.
Is this nomral. Why am I having problem getting a signal to my production monitor all the sudden. Does the footage being PAL have anything to do with it? I don't recall having this problem with my normal NTSC footage.
Also every so often when I hit the "preview to external monitor" button everything freezes and my cursor becomes an hourglass. The only way to "un-freeze" it is to turn off my device I'm using to output to external monitor whether it be my deck or a DV camera. Is this a known issue also?
Glen Elliott is offline
Old January 14th, 2005, 11:20 AM   #156
Vegas and Sound Forge
If I use Sound Forge with Vegas, will it place my Sound-Forge-edited-audio (taken straight from the time line from off of Vegas with the "Open in Audio Editor" function) back into the same position as it was before it was edited? Just how seamless is this process? Hope this question makes sense, thanks.
Glenn Gipson is offline
Old January 14th, 2005, 11:31 AM   #157
Sponsor: JET DV
When you return to Vegas, it will be added as a TAKE to the original audio clip.
Edward Troxel is offline
Old January 14th, 2005, 12:34 PM   #158
Does that mean that it will be added on a new track?
Old January 14th, 2005, 12:53 PM   #159
Sponsor: JET DV
No. It is added as a TAKE to the original audio. Both are on the same track in the same position. You can swith back and forth between them (when it is selected) by pressing "T".
Takes allow you to place multiple items in the same event and easily switch between them.
Old January 14th, 2005, 12:54 PM   #160
Ahh, I understand, thanks! I will be ordering Sound Forge soon, because I need to "clean up" my dialogue for my feature.
Old January 14th, 2005, 12:58 PM   #161
Old Boot
No, a take is another "version" of an event. So, omce you've got the "versions" back into the Media Pool in Vegas - as per Edward's comments above, I highlight the events - these are WAVs for me - RIGHT click and DRAG the group - here it was 4 versions - and as you drop these onto the audio portion of the event and release, you get a drop down menu. I select "Add AS Takes" . . this gives the option to Preview all the versions, one at a time. You do this by Right clicking the Audio and going waaay down to the Take section and there you will see the various Takes of the same Audio! Select which one is the one you prefer!
So, that's the TAke on Takes!
Grazie
Graham Bernard is offline
Old January 14th, 2005, 01:01 PM   #162
Old Boot
Ah! yah beat me ... G :)
Old January 14th, 2005, 01:46 PM   #163
Greetings Ineta,
Riga is of course the birthplace of one of the all time great engineering wonders of photography - The original Minox 8x11!
Edward wrote:
>>>You'd honestly be better off taking the original MPEG file and rendering to a new DV-AVI file, editing with it, and then rendering back to MPEG1.
Edward,
Does Vegas perform this?
I thought you had to render the Mpeg out from Womble or one of the specialized Mpeg programs, and then bring it back in to Vegas.
Brian
Brian Mitchell Warshawsky is offline
Old January 14th, 2005, 03:01 PM   #164
Sponsor: JET DV
Yes, Vegas can render from MPEG to DV-AVI.
Old January 14th, 2005, 04:56 PM   #165
Is your CPU overclocked? I had problems with Vegas and this. My machine ran perfectly for EVERYTHING else, without a hitch. But when rendering, sometimes it'd reset. So I dropped the clock back down and it's all good now.
Aaron
My Website
Meat Free Media
Aaron Koolen is offline
