what is wrong... - Page 2 at DVinfo.net
Old August 27th, 2009, 10:51 PM   #16
I run XP64 on the laptop and Win7 64 on the editing desktop. I have been immune to these crashes you and others seem plagued with. Your XP system is only allowing 2GB of RAM for Vegas and whatever else might be running. I suspect that your render has less than 1.25 GB free available when it starts, and that is quickly eaten up. I suspect many people are having the exact same issue.
You are pushing things by:
1. Editing HD
2. Running a 32 bit OS
3. Using long-GOP on the timeline
4. Overclocking the CPU
Given these parameters, it is absolutely no surprise you are having issues. Enjoy Florida. I do every day... rain or shine.
Old August 30th, 2009, 10:57 PM   #17
Marius, you could also upgrade to Win XP Pro 64, if you are hesitant to go the vista route. That is assuming your system is 64bit compatible and capable of more ram. Correct me if I am wrong, but I believe Perrine uses XP64 as well.
EDIT: Opps, Perrone I didn't see your reply to this already.
On an additional note, with the exception of some preview window choppiness, I have had a pretty good experience with 9.0a on my Quad core system. And I have had no crashes, rendering or otherwise using M2T and MXF for HD and avi source files for SD.
Basic Specs:
XP Pro 32bit SP3
Intel core 2quad Q6600 @ 2.4GHz
2.40 GHz 3.25 GB RAM (4GB actually installed)
No RAID - but all 7200rpm SATA-II drives internally 3.75 TB (with additional 4 TB external)
3x-HD1000u - Ikan 8000HD- custom i7 PC - Vegas Pro 13 and 11 64 bit - Premiere Pro CS4 - and a whole mess of other equipment...
Bryan Daugherty is offline   Reply
