Correct use of Secondary Color Correction at DVinfo.net
Old August 27th, 2009, 04:43 AM   #1
I use primary color correction in Vegas 8 and now 9 constantly. I'm not sure I understand the correct time in the workflow and methodology for using secondary color correction and its fundamental purpose as aoposed to primary correction.
Any pointers?
Roger Shealy is offline   Reply With Quote
Old August 27th, 2009, 08:09 AM   #2
I believe Color Correction adjusts the overall color balance and exposure. Adjustments effect the entire image. Secondary CC is used after the overall adjustments are done. It's used to modify a single color, such as changing the jersey color of a football player.
The overall CC should be done first.
Paul Cascio
www.pictureframingschool.com
Paul Cascio is offline   Reply With Quote
Old August 27th, 2009, 04:16 PM   #3
Thanks Paul, I'll have to give Sedondary CC a try with that in mind.
Old August 27th, 2009, 05:36 PM   #4
Yeah Paul, thats kind of what I do too. I use Colour correction to balance all the colours on individual clips, and also to acheive the desired look/colour for the sequnece by using a further CC filter on the Output FX. I use the secondary CC for colour effects or when I just need to tweak one thing a little bit without disrupting the whole image.
John Wiley is offline   Reply
