Keeping VEG files - deleting video at DVinfo.net
Old September 27th, 2004, 08:16 PM   #1
Can I save my veg files and remove the video files from my hard drive? Would I be able to recreate my project if needed at a later time? Could I recapture the tapes and reconstruct?
Doug Struchen is offline   Reply With Quote
Old September 27th, 2004, 08:19 PM   #2
Sponsor: JET DV
Any files that were captured in Vegas Capture can be recaptured (recommend you also save the "sfvidcap" file). To recreate your project, you will need the original tapes, the VEG file, and any "additional media" used in the project such as WAV files, pictures, etc...
Old September 27th, 2004, 08:43 PM   #3
Thanks Edward - I though I could. I saw so much in the class here in Atlanta - but didn't have Vegas yet . I hope you guys make it back here next summer so I can put two and two together!
Old September 27th, 2004, 08:52 PM   #4
Sponsor: JET DV
Glad I had an opportunity to make it down that day. It was great to meet Spot in person and get together with Gary and Tim again. All the Sony guys were great too.
Old September 27th, 2004, 09:30 PM   #5
You mention capturing in Vegas and saving the sfvidcap. Does it make a difference if I capture using scenealyzer? I have a wireless mic going to the 2nd channel.
Old September 28th, 2004, 01:49 AM   #6
RED Code Chef
Although this is possible I have to point out it may be a dangerous
thing to do. Yes you should be able to recapture exactly what you
captured the first round, but what if your not able to. What if you
are a few frames off or some tape etc. is missing.
Personally I much rather make an extra backup on DVD's or
another harddisk (fairly cheap to buy these days and a big one
can store multiple projects usually) to make sure I can easily
go back and have another copy somewhere.....
Rob Lohman, visuar@iname.com
Old September 28th, 2004, 04:54 AM   #7
I wouldn't mind making a backup - but at 20 gig's a game, I couldn't afford the time to burn, the disks or hard drive space. I'll just have to let the mpg be my backup and not worry about recreating my veg file.
Old September 28th, 2004, 07:28 AM   #8
Sponsor: JET DV
Capturing with Scenalyzer is fine AS LONG AS you can capture an exact copy. For example, if you just capture a tape, the first segment may start at a slightly different point UNLESS you have taped a short piece on the front so it can split based on date/time.
For example, suppose the first segment on the tape is 40 minutes long. If you don't have, say, a 30 second header on the front for it to find the beginning of the first segment, the rewinding may cause capturing to start at a slightly different point.
I always make sure I have date/time scene detection on when using Scenalyzer. If I could enter batch ranges in Scenalyzer, I could consider using it full time instead of Vegas capture. Right now I use Vegas capture for everything except my 4-channel audio segments.
One thing you CAN do with scenalyzer is take a series of clips and have it record to tape. It can then bring it back in with file names intact.
Old September 30th, 2004, 03:19 AM   #9
pardon the ignorance, but what is the sfvidcap file for?
Gerald Yuvallos is offline   Reply With Quote
Old September 30th, 2004, 07:04 AM   #10
Sponsor: JET DV
It's the file that saves the information from the Capture program. You can have different sets of files with different sets of tape names for each of your projects. It make recapturing much easier.
Old October 3rd, 2004, 05:09 AM   #11
much thanks for the answer Edward :)
Old October 4th, 2004, 06:00 AM   #12
Is'nt there a way to save the whole project with the video that was already captured?
Then save it out to dvd as a data file?
Ron Guilmette is offline   Reply With Quote
Old October 4th, 2004, 07:02 AM   #13
Sponsor: JET DV
There's no reason why you couldn't store the actual video files on external media. However, remember DV-AVI is 13Gig per hour meaning you would need 4 DVDs to hold ONE hour of footage. I'd rather just keep the master tapes.
Old October 4th, 2004, 09:20 AM   #14
Gotcha!
Old October 4th, 2004, 09:47 AM   #15
Images: 10
You can save the VEG file and select "Copy and trim media" button in the "Save As" dialog box. This will save only your veg file and the pieces of the media files you actually used. It will cut the remainder of the unused video files.
Bill Ravens is offline   Reply
