#16 |
Jamie,
As was asked prior, your camera (which is a great little camera for what you are doing) shoots wide screen. Is there a rreason you only sdhoot 4:3? Considering most of your video will be computer based I would think you would want to shoot wide screen. In a day or two I will run a couple tests with my sd camera in both wide and 4:3 and see if I can replicate what your problem, and then see if I can sort it out.
DATS ALL FOLKS Dale W. Guthormsen |
#17 | |
There is a reason I shoot widescreen. I film skateboarding mostly and I use a fisheye to follow the skaters around using my skateboard. I try to get as close as possible to the skater to give things a cool look without cutting off any part of the skaters body. If I film in 16:9, I will be more likely to cut off heads while trying to get close up shots. Thank you, I know the problem must be one of the render properties, but I see nothing wrong with them when I look.
Vimeo |
