Vegas users, whats the best DVD settings? - Page 2 at DVinfo.net
Old August 19th, 2004, 03:24 PM   #16
When I've attempted this in TMPGEnc an error message is generated stating that the selected resolution is beyond the DVD standard...and forces me back to the encode selection window, until I select a DVD compliant resolution.
I encoded an MPEG2 stream @ 1920x1080 last night before i posted. I notice you're using this v3 Xpress or something. I'm not familar with it but in version 2.5 which i use... you simply unlock the standard template profile and then go your hardest with all the relevant settings... it DOES do it. I highly doubt in v3 (a newer version) that it would have less functionality. Though these days i wouldnt rule i tout O_o :)
Welcome... to the real world!
Daymon Hoffman is offline   Reply With Quote
Old August 20th, 2004, 08:24 AM   #17
<<<-- Originally posted by Mark Paschke
Is Avisynth plug-ins a downloadable, pay for, or part of Vegas, I am not at my studio computer right now so I cant check -->>>
The Avisynth/Virtualdub denoise filters are open-source and generally free. Do a Google search for Virtualdub filters and you should find plenty.
The adaptor for loading Virtualdub/Avisynth filters in Vegas (PluginPac) can be found at:
http://www.debugmode.com/pluginpac/
To Daymon: I must correct myself!! You're correct, TMPGEnc 3 XPress encoder does encode MPEG2 HD.... I just went back into it and did a short render. At this rate, every DV editing app will handle HDV before the end of the year!!! If it doesn't rain it pours.....
Steve Crisdale is offline   Reply
