Vegas downloadable demo - Page 2 at DVinfo.net
Old August 18th, 2004, 07:47 AM   #16
RED Code Chef
Just drag it from your explorer outside of Vegas or from the
explorer window inside Vegas (see left bottom of the screen)
onto the timeline. If you drag it over an existing track it will
put it there. If you drag it below any tracks it will create a new
one.
Ofcourse you can also go through the trimmer if you want to
trim it first.
Rob Lohman, visuar@iname.com
Old August 18th, 2004, 07:48 AM   #17
Sponsor: JET DV
Just drag it to the timeline. If you want to insert it before other clips, either turn on Ripple or insert the necessary space first.
Old August 18th, 2004, 08:19 AM   #18
But when I try that the existing clips seem to slide under each other. Can I "lock" them so that the entire track moves together during the insert?
Old August 18th, 2004, 08:47 AM   #19
Sponsor: JET DV
It depends on your ripple settings. Try changing them so that they affect everything.
If you can't get that to work, just manually insert the proper spaces "Insert - Time..." will let you manually insert the proper time.
As a third option, you could always select the necessary events and manually move them.
Old August 18th, 2004, 09:07 AM   #20
Thanks again. I will try all of these when I get hame. Thanks again Bob
Old August 18th, 2004, 08:25 PM   #21
Yes, it works! Thanks. I am off to Mississippi a happy man. Thanks again. Bob
Bob Safay is offline   Reply
