#16 |
Yes, but that wouldn't work for tape, only for BDs.
#17 |
I have one more question. I have another project that was shot in 60i with A1 and I am mixing 5D files. I followed the method to convert everything to upper field first and I have the same crashing problem. Should I use lower field first? Progressive? I have a lot to learn about this stuff. I appreciate your help.
#18 |
If your output is going to be interlaced, keep it interlaced, upper field first. If it keeps crashing, maybe you would want to update to Vegas 9 (try the trial), and if that crashes too, research to find another editor that doesn't give you the same headaches.
#19 |
Thought I was out of the woods but not quite, so I upgraded to Vegas 9.0a. All I get is out of memory errors!!!!!*&%^$#(#
I have 4gb of memory. |
#20 |
Sponsor: JET DV
Wait a few days until 9.0b is released. In the meantime, revert back to 9.0.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#21 |
ooh that sounds good. Thanks Edward.
#22 |
Just loaded up 9b same problems. My love for Vegas has soured. I can render my projects in version 8 or 9.
#23 |
Anthony,
I'm no techie, but your workflow seems pretty messed up. You're rendering back to tape to use as a master file? I tried that once a long time ago, never again, it seemed like a good idea at the time though. If you render out at 1440x1080 .avi (cineform) you will have a big file of high quality, that should be far better than going back to 720 tape. Then you can then resize (using VirtualDub) to 720x480 for SD-DVD.
C100, 5DMk2, FCPX |
