AVCHD & HDV in Veg 8.1 at DVinfo.net
Old August 16th, 2009, 12:05 PM   #1
I'm interested in comments re mixing the above in a project as I have not done this before. I'm in PAL land - (sigh, - bliss), and notice AVCHD is upper field first & HDV is lower field by default as an example. Should I set them the same or doesn't it matter ?
Any othe things to look out for ? -
I wish to have an AVCHD track above an HDV and cut back & forth with a common synced sound track.
Thanks.
RonC.
Ron Cooper is offline   Reply With Quote
Old August 18th, 2009, 05:07 PM   #2
You are mistaken. They are both upper field, so you can just go ahead and mix them. It's DV that's lower field, not HDV.
Eugenia Loli-Queru is offline   Reply With Quote
Old August 19th, 2009, 04:27 PM   #3
Thanks, Eugenia.
I stand corrected, with fingers crossed !
RonC.
