Project Recovery - Desperation!
Hello all,
I just had Vegas 4 crash on me while working in the trimmer. My screensaver engaged which it appears caused Vegas to crash. Of course I had not saved my work for about ten minutes. I re-opened the project to see what I lost, and I lost all of my work. I did check my preferences and "Enable Autosave" is checked. My question is - where does Vegas save the autosaved file to - the file I am working within, or a temp location on the drive? Is there any way to determine whether this info has been saved elsewhere or not? As always, thanks for your help.
Lance Spratt |
Old Boot
Look for the backup - *.bak - file .. it should be in the same folder that you kept the original .. yeah?
When I get a crash, my autosave comes back when I reopen Vegas asking me to open and save it as a nmed file . .did you get this when you re-openned vegas? Grazie |
Grazie,
Thanks for the heads help! It was all there. Just a note - After it crashed, I opened the file I was working in and it did not come up with the question to open the autosaved file. It was when I launched the program from the Start that it came up and allowed me to recover my work. Thanks agin for the support!
Lance Spratt |
Old Boot
Itzah PLeazure
Excellent! ! ! !
Now, why did it go South when in Trimmer .. THAT'S a new one on me . . .h m mm .. Grazie |
#5 |
Grazie,
Good question! As I have no time to investigate, I have turned off my screen saver and all is well. This may be more related to the computer than Vegas itself. Time will tell. Thanks again.
Lance Spratt |
#6 |
RED Code Chef
Screensavers are in my mind the root of all evil. Well, that might
be a bit over the top, but let me explain. First: almost no monitor needs it these days anymore. And power saving on your monitor is far better than a screensaver anyway. Second the screensavers people install are getting funkier and funkier taking more and more resources and people start complaining about slow systems and whatnot. It has also been known that some cool screensavers came with virusses etc. since a lot of people seem to like cool screensavers. Lastly it can interfere with others programs like you found out, although that SHOULD not happen. Then it begs to differ why have a screensaver at all. I have a very high tech feature I employ: turn of my monitor. Yes, it is a radical principle, I know. So to answer everybody's question to what I do on my laptop? I close the lid. I have Windows setup that it doesn't do any action at all (control panel -> power options -> advanced) and the screen will turn off. Otherwise I could also simply disable the monitor by switching to external out only. Thus far my rant on this topic.... I'm glad you where able to recover your project though Lance!
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#7 |
Capt. Quirk
Not only are screensavers a thorn to editors, but those really cool sounds that people use on their computers, can wreak havoc too...
I used to have some Star Trek sounds on my PC. One day, as I was proofing a client's video I had just finished. Out of nowhere, in the middle of the thing, you could clearly hear the Enterprise's doors opening... grrrrrr! Back to the drawing board...
www.SmokeWagonLeather.us |
#8 |
RED Code Chef
Good point Keith:
The first things I do after installing XP: 1) disable themes, go back to classic Windows look 2) disable screen saver 3) select "none" for sounds 4) disable things like showing only most used items and packing taskbar icons etc. You get the idea <g>
#9 |
Capt. Quirk
Agreed, Rob. I go a step further by setting the power saver to about an hour on my edit machine. No solid reason, just cuz... I get a feeling that it is a problem just waiting to screw my rendering.
#10 |
RED Code Chef
Yeah, I do similar things. It was just a short item list. I change a
LOT more than the short list I put up earlier. Nothing beats a good customized and tuned system!
#11 |
if you really want to clean up XP (background proggies, etc.)
goto http://www.blackviper.com/WinXP/servicecfg.htm and put your swap file on a diff partition (or drive if possible) than OS. and video on its own drive too
Trey Perrone |
