Help...vegas 7 error at DVinfo.net
Old August 11th, 2009, 07:46 PM   #1
I get a message lately that says "An error occurred starting Vegas. Failed to register with windows terminal services."
Vegas appears to be working fine, but i would like to know what this is.
tayproductions
Derek Grimes is offline   Reply With Quote
Old August 12th, 2009, 06:53 AM   #2
Sponsor: JET DV
You apparently went into your "Services" and turned off Terminal Services. Turn Terminal Services back on and the error message will go away.
Old August 12th, 2009, 02:49 PM   #3
Tried That
Edward,
I tried that and started the terminal services. When I start it i get a message "the terminal services service on local computer started and then stopped. Some services stop automatically if they have no work to do..."
What am i doing wrong?
tayproductions
Old August 13th, 2009, 07:58 AM   #4
Sponsor: JET DV
The only thing I can think of would be that some other service that Terminal Services needs also is not running.
To be honest, as long as you don't mind clicking on OK, it won't affect how Vegas works for you. It would only affect if you were bouncing between multiple logged in users.
Edward Troxel is offline   Reply
