What should I render too? at DVinfo.net
Old July 30th, 2009, 10:42 PM   #1
Ok, so I need to put a video online in very high quality and will be using vimeo. BUT, what should I render my m2t files too, before I upload them?
thanks in advance!
Andy Loos is offline   Reply With Quote
Old July 30th, 2009, 10:50 PM   #2
Mpeg4 (AVC) 1280x720 6Mbps. Use either the Sony or Mainconcept choices. Either works just fine.
Old July 30th, 2009, 11:01 PM   #3
Here's a link with screen shots for you.
Exporting with Vegas for Vimeo HD
Old July 31st, 2009, 08:45 AM   #4
thanks guys Alot!!
Now when you go to File, then properties, what settings do you have set? What is pixel format: 8bit, is this what I should be using?
Motion Blur type: Gaussian?
When I look at deinterlace method, for online videos I should use Interpole fields, but what is blend fields then? is this used for TV?
Old July 31st, 2009, 03:19 PM   #5
Please use it as in the tutorial. If the tutorial doesn't say anything about it, just use the defaults. These are the simplest options.
Eugenia Loli-Queru is offline   Reply
