error - can't burn a single BluRay at DVinfo.net
Old July 28th, 2009, 08:43 PM   #1
I got this message:
File name: STREAM/00001.m2ts
Status: TSWrapper.dll::CTSWrapper::ProcThreadMain::Video buffer underflows. -
HOW TO PRODUCE BLURAY IN VEGAS!!!!
Marius Boruch is offline   Reply With Quote
Old July 31st, 2009, 03:20 PM   #2
Use the MainConcept encoder to encode AVCHD disks, not the default SonyAVC one. SonyAVC has a nasty bug where often it crashes when exporting in high resolution. It's a well known bug that has been bugging mostly Platinum 9 users.
Eugenia Loli-Queru is offline   Reply With Quote
Old August 10th, 2009, 11:44 AM   #3
It doesn't work; when I use mainconcept and render it to bluray spec. it shows me in Architect 5.0 that the file is in wrong format.
(when I render short file then everything is OK but when I render let's say 3.5 hr project then I got this error.
what is going on? How to produce long BluRay using mp4 compression?
I can't even open it back in Vegas; it shows me an error that couldn't be determined!!! (both files the one rendered in Sony codec and Main Concept one)
