Trouble nesting .veg file at DVinfo.net
Old June 26th, 2009, 11:18 AM   #1
I'm attempting to nest a .veg file in my master timeline and running into a problem. When I click on the .veg file in the explorer tab (to drag and drop in timeline), I get an hourglass than hangs forever -- and Vegas is unresponsive.
It only happens to this one particular .veg file. Other .veg files that I am using in this particular project can be placed within my master timeline with out a problem.
Any ideas what's up?
Thanks --
James Binder is offline   Reply With Quote
Old June 26th, 2009, 11:57 AM   #2
Sponsor: JET DV
If you "Open" it instead, does it open? Any errors upon opening?
Old June 26th, 2009, 12:41 PM   #3
Opening it by itself works fine - no problems.
I did get it to finally work by 'opening' the problem .veg file first in one instance of Vegas, then opening another instance of /Vegas (with my master timeline) and drag/dropping the same .veg there.
Humm - don't know if that's coincidence or not -- haven't had time to try and replicate to see if that was the fix. If it was, not sure why I would have to do that...
The veg file I'm, attempting to open has multiple video tracks with track motion...
Vegas 8c/win xp
