Vegas 9 and Windows 7 at DVinfo.net
Old June 24th, 2009, 12:19 PM   #1
My experience with Vegas 9 64 on Vista 64 bit has been very unhappy.
Then I installed Windows 7. While my pronouncement is preliminary to say the least, I am absolutely loving Windows 7, it flies and seems to destroy Vista. In addition, Vegas 9 64 bit seems to operate much better with Windows 7.
I have never "fallen in love" with an OS before, but this experience so far comes very close.
I was not unhappy with Vista particularly, but Windows 7 is so much more responsive. I feel like it is actually utilizing all 12gb of ram...it is so fast I'm actually in shock.
In a day or two I may find bugs, etc., and I'll report back, but on this first day I'm a very happy camper.
Windows 7 gets a big thumbs up from me.
To quote HPs Chief Technology Officer: "The quality of the code is absolutely stellar". Based on what I'm seeing it is indeed.
Old June 24th, 2009, 04:53 PM   #2
Looks like MS got the message on priorities. Vista was centered on DRM and system security and and flashy but non value-enhancing UI. Noble goals, but is putting the cart before the horse.
The most secure OS in the world isn't wortjh a hill of beans if it's slow or difficult to use.
Vista wasn't that bad, but no wonder so many refused to upgrade. Maybe Apple and Adobe's dominiance in the Media/Media Tools market gave them a good scare.
Gene Gajewski is offline   Reply With Quote
Old June 25th, 2009, 03:20 PM   #3
Well, there is at least one issue with me for Windows 7, and that is intermittent issues with internet connectivity. Sometimes it works, and sometimes it doesn't.
Most of the time it does, and I'm still enjoying it enough I am overlooking the above issue so far.
Old June 25th, 2009, 03:41 PM   #4
I haven't seen that problem Jeff...did you download all the updates?
BTW...MS is offering a 1/2 price pre-purchase deal...
Windows: Windows 7 Pre-Order Offer
Bob T.
Old June 25th, 2009, 04:08 PM   #5
That is awesome Bob...
I have downloaded the updates...when I did a search I found some others with issues of the same type, not tons, but a few.
I found by uninstalling an reinstalling the drivers for my NIC it solved the issue.
Old June 28th, 2009, 12:50 PM   #6
The issue of internet connectivity is happening about once a day...I have found by unplugging from one LAN input and plugging into the other the problem is solved. Primitive but effective and simple.
Old June 28th, 2009, 01:59 PM   #7
From what I read, one can't go directly from Windows XP Pro OEM to Windows 7. One has to buy Vista and THEN get Windows 7.
Is this correct?
If so, then so much for the 1/2 price pre-purchase deal. :(
Information so far leaves one begging for answers.
Danny Fye
VidMus Video - Music Productions
www.dannyfye.com
Danny Fye is offline   Reply With Quote
Old June 28th, 2009, 09:09 PM   #8
I've been a few day on Win 7 64 - so far no issues to note of. Am happy with it - will post if anything negative occurs.
Old June 28th, 2009, 09:13 PM   #9
If the upgrade requires installing on top of old installation of Vista it will be a deal breaker anyway, for me. If we will be able to use the upgrade to do a clean installation then I'm buying it. Vista's upgrade requires, as I recall, installing on top of another OS and that is something I never have done nor will I. Let's keep our fingers crossed!
Old June 29th, 2009, 01:59 PM   #10
The beta install allows a choice of either clean install or 'over' install. Your pick. I chose the over install - and it's performing well. I'm not sure the upgrade 'over' install works in what most believe the conventional process of simply overwriting files - it makes a really big deal of collecting file and settings information, performing the install and then copying over the data to be transferred. Took a couple of hours! Holy Smokes! I'm sure a regular clean install would've been done in 20 minutes. I'm also pretty sure you can perform the clean install without first formatting the drive or deleting anything in advance. In this case the upgrade would simply place the old data in a renamed directory.
Old June 29th, 2009, 02:20 PM   #11
From what I've read over at sevenforums.com, all you need is the Vista disc to prove you have it, it doesn't have to be installed.
Just like the old days with Win95 and XP....
Bob T.
Old June 29th, 2009, 02:29 PM   #12
Gene, I am running the RS version and same thing, you can choose, but I'm skeptical that it will be the case with the upgrade retail version, though from what Bob says I'm cautiously optimistic.
Old June 29th, 2009, 10:22 PM   #13
Can't blame you at all for being sceptical - MS earns that with a long history of behavior that'll take a long time for them to come out from under.
Seem like Windows 7 did a lot of work under the hood on file I/O. It just tickles me to see the difference. I have this one .veg with about 64 short clips and to watch it load with thumbnails is impressive compared to what used to be a lengthy wait under Vista.
Old June 30th, 2009, 06:50 AM   #14
Read the FAQs Danny, it has answers for you and I.
First you can upgrade from XP, and second it explains you can do a clean install.
This is great news!
http://www.microsoft.com/windows/buy...order-faq.aspx
Old June 30th, 2009, 06:53 AM   #15
Important Note:
There are a limited number of copies...newegg has already sold out of the home edition.
