rendering part of time line at DVinfo.net
Old June 17th, 2009, 01:00 PM   #1
Hello,
I'm using Vegas 7 and I'm going to have to render 75 minutes little by little, since Vegas can't do the whole thing without crashing. I can't cut and paste part of the time line in an other occurence of Vegas as it would mess up some track motion effects.
So is there a way to select part of the time line and only render that part?
I don't see any short cut when I right click or when i go to options or else
thanks
Larry
Larry Secrest is offline   Reply With Quote
Old June 17th, 2009, 01:13 PM   #2
Sorry don't have Vegas in front of me, so this isn't going to be very exact. Highlight the bit you want with (not sure of the name for it) so have you the little yellow flags either side of it. When you click "render as" tick the box for render work area only.
Jon Rule is offline   Reply With Quote
Old June 17th, 2009, 01:34 PM   #3
Drop markers on your timeline, double-click between each pair to highlight that section only and select "render loop region only" in the "Render As" dialogue box.
This way, you don't have to play around with finding the proper in & out points each time.
Old June 17th, 2009, 08:05 PM   #4
Sponsor: JET DV
Or create a series of regions on the timeline and go to tools - scripting - batch render and use the option to render all regions separately.
Lots of ways to do this.
Old June 17th, 2009, 08:39 PM   #5
Ed- Would downloading your script help him out or is the script in Vegas 7 good enough? I can't remember v7 well enough....
3x-HD1000u - Ikan 8000HD- custom i7 PC - Vegas Pro 13 and 11 64 bit - Premiere Pro CS4 - and a whole mess of other equipment...
Bryan Daugherty is offline   Reply With Quote
Old June 17th, 2009, 08:46 PM   #6
Thanks all of you, I'm going to try that
Larry
Old June 18th, 2009, 06:10 AM   #7
Sponsor: JET DV
Bryan, both will work but the version I revised has more options so might be better to use.
Edward Troxel is offline   Reply
