Vegas equivalent to FCP 8 pt garbage matte. at DVinfo.net
Old May 31st, 2009, 10:57 PM   #1
I have some footage to key, I want to get rid of the boom mic etc. In FCP the 8 point garbage matte masks it out, what's the name of the tool in Vegas 7 that does that?
Anyone know of a video tutorial on the howto?
Old May 31st, 2009, 11:22 PM   #2
In Vegas you go into the pan/crop tool. On the bottom where the timeline is there is a check box for a mask. Check that and grab the pen tool and outline your subject with greater accuracy.
Ken Campbell is offline   Reply With Quote
Old May 31st, 2009, 11:55 PM   #3
Found the mask box, where's that little ole pen tool?
Old June 1st, 2009, 12:14 AM   #4
Old Boot
What full name version of Vegas7 are you using? Have you CHECKED the Mask Square? Do you see a CHECK tick?
On mine there is a column including the "Show Properties" Icon and Pen Tools. If you don't see the Properties hit the "Show Properties icon or slowly drag this column edge of the workspace "edge" inwards.
Once you have ALL these Properties showing, then select the Pen tool and click on the Workspace area and you will then see all the Pen Tools Properties coming into play.
Grazie
Old June 1st, 2009, 01:18 AM   #5
I have version 7.0a vegas pro. I don't see any pen tool under "show properties".
Old June 1st, 2009, 01:57 AM   #6
Old Boot
Have you checked the Mask Box?
Grazie
Old June 1st, 2009, 02:02 AM   #7
Old Boot
You are on Vegas 7a - V7 finished at 7e - you may want to consider upgrading to the final free iteration of Vegas7? Up to you.
Grazie
Old June 1st, 2009, 03:06 AM   #8
Grazie
Okay, i was looking for something actually called "Pen tool" but it's called "Anchor point creation tool". So that works easily to outline my subject. So once outlined, how do you get the mask or matte to take effect? I'm still seeing a light stand and mic in the preview window despite the subject being haloed by pan and crop.
Old June 1st, 2009, 03:24 AM   #9
Old Boot
Had you checked the Mask box? It would seem so. It is an "Pen" Icon. Did/had you seen that previously? The "Pen" Icon?
So that works easily to outline my subject. So once outlined, how do you get the mask or matte to take effect? I'm still seeing in the preview window despite the subject being haloed by pan and crop.
What do you mean "haloed" and is the "What I want to get rid of the boom mic" what is that compared to the "...light stand and mic"?
Grazie
Old June 1st, 2009, 03:36 AM   #10
Grazie
the mic is over head and a light stand off to the side, with an 8 point garbage matte in fcp you could easily remove that. wat are the basic steps?
Old June 1st, 2009, 03:45 AM   #11
Old Boot
Is an 8-point garbage matte 2 squares of Matte? Meaning one matte with 4 points and another square of 4-points? Is that what you mean?
Grazie
Old June 1st, 2009, 03:46 AM   #12
Old Boot
If you send me a Still I'll send you a VEG in Vegas7.
Grazie
Old June 1st, 2009, 03:49 AM   #13
Old Boot
In Vegas you get a "hole" when using this process. If you have underlying media it would show-up in the holes. Are you saying FCP fills the hole with an alternative option?
Grazie
Old June 1st, 2009, 03:51 AM   #14
Grazie
I have a woman in front of a greenscreen, you can also see the mic overhead, and the light stand on the left. I DO NOT want those objects in the shot, so it was suggested to me that I try the pen to draw an outline around the subject therebye removing the offending and superfluous objects and have clean key. Right now, I have an outline around the subject. What are the next steps?
Old June 1st, 2009, 03:57 AM   #15
Hi Brian, once you have outlined the subject, and closed the circle, you should be done. Just get out of the pan/crop tool and go back to the timeline. Your boom should be gone.
The masking capabilities are really powerful in Vegas and rivals those of After Effects. You can do full blown rotoscoping in Vegas. And the tool is really flexible as you can also do negative masking. For example, you could also outline just the boom mic and then choose the negative mode, which will keep everything except what you selected. You can even have many masks inside and each with different modes. With Vegas you are only limited by your imagination!
