Video Wall at DVinfo.net
Old May 24th, 2009, 10:43 PM   #1
Video Wall
Good evening,
can I do this?
I want to run my first two thirds of my video as a single full widescreen, 1.33.
the last third I want to run video wall with either 4 or 6 panes simultaniously of course, then end with full frame credits.
any necessary trick to do it?
thanks!!!
DATS ALL FOLKS
Dale W. Guthormsen
Old May 25th, 2009, 12:07 AM   #2
Old Boot
Originally Posted by Dale Guthormsen View Post
can I do this? I want to run my first two thirds of my video as a single full widescreen, 1.33. the last third I want to run video wall with either 4 or 6 panes simultaniously of course, then end with full frame credits.
Can you do it - yes. But why are you asking the question?
A] Tracks
B] Patience!
But slightly more seriously, what is it you think is going to be difficult?
My take on this is:
1] The WS is the Project setting.
2] The other media you can squish using Pan/Crop OR Track motion.
3] The FULL Frame credits will be on the topmost track, visually spanning ALL the tracks in the wall below.
I've got both Edward Troxel's Excalbur and VASST's UliSPro - both have the facility to setup these Video wall type projects, but you can HomeCook these too.
Dale, just do it. If you get anymore issues get back here!
Grazie
Old May 25th, 2009, 12:58 AM   #3
Grazie,
Pressed for time, just wanted confirmation before i trudge ahead- can't afford to waist any time before tomarrow evening.
will do it in the morning, wait a minute, it is morning!
Thanks!!
DATS ALL FOLKS
Dale W. Guthormsen
Old May 25th, 2009, 01:04 AM   #4
Old Boot
8:03am here - early riser?
G
Old May 25th, 2009, 04:26 AM   #5
Here's a free video wall for vegas, it even gives a docking tab, i i've used it a couple of times and it's brilliant and very easy to use.
VideoWall Documentation
Paul.
Round 2
GH5,FZ2000
Old May 25th, 2009, 05:16 AM   #6
Incredible! Thanks for the link!
Old May 26th, 2009, 12:17 PM   #7
Yes, but only works in Vegas 8.
Puttin the wet stuff on the red stuff!
Terry Esslinger is offline   Reply With Quote
Old May 26th, 2009, 12:53 PM   #8
Sponsor: JET DV
According to the Sony forum, it works fine in Vegas Pro 9. It simply installs in a Vegas Pro 8 specific folder so you need to copy the files into the corresponding Vegas Pro 9 folder.
Old May 26th, 2009, 03:22 PM   #9
As per that same forum
"A version for 9 will be available soon"
Old May 27th, 2009, 08:41 PM   #10
I looked for it in Vegas 8 folder but couldn't find it.
Harold
BhagaVideo.com
Harold Brown is offline   Reply With Quote
Old May 27th, 2009, 08:52 PM   #11
Thanks for the information gentlemen!!
The job was actually very easy, just built the wall seperately, rendered it to cineform avi and then imprted it to the project timeline.
DATS ALL FOLKS
Dale W. Guthormsen
Old May 27th, 2009, 10:23 PM   #12
Images: 10
Harold...
copy from:
C:\Documents and Settings\user name\Application Data\Sony\Vegas Pro\8.0\Application Extensions
copy to:
C:\Documents and Settings\user name\Application Data\Sony\Vegas Pro\9.0\Application Extensions
Old May 28th, 2009, 10:03 AM   #13
Well now, how did Edward edit a Bill Ravens post?
Are all of our posts subject to edit by someone else?
Old May 28th, 2009, 10:15 AM   #14
Images: 10
big brother is watching, Terry. Ed has super-powers
Old May 28th, 2009, 11:11 AM   #15
Sponsor: JET DV
Terry, I'm a moderator on this forum. I only made a modification in this case to further clarify. Guess I could have simply made a new post but figured it would be easier by editing. I very rarely edit things but, occasionally, things do get edited or removed or locked. There definitely was no malicious intent here.
Edward Troxel is offline   Reply
