How much space do you need to burn Blu-ray Disc On DVDA5 ? at DVinfo.net
Old May 15th, 2009, 06:34 PM   #1
I have a project that I rendered from Vegas8 for a Blu-ray Disc, It is 22.9GB when I imported to DVDA5, But when I tried to burn it I get a message "There is not enough space in the temporary files folder for preparing the disc"
I have 780GB of free space and It will not let me go to the next step.
How much space to you need to prepare a 22.9GB Blu-ray Disc to burn ?
Michael Ojjeh is offline   Reply With Quote
Old May 15th, 2009, 07:15 PM   #2
At least twice the space is normally needed to assembly a disc image. But where is your temporary folder for DVDA5? I suspect your temporary folder for DVDA5 is on your boot drive which is getting full. Go into properties and set you temp folder to the drive with lots of space on it. I have a hard drive dedicated to temp folders from all my applications.
Ron Evans
Old May 15th, 2009, 08:07 PM   #3
Ron, I do have the temporary folder for DVDA5 on a different drive then my boot drive, and It has way more then it needs.
Old May 15th, 2009, 08:44 PM   #4
I am all set, I forgot about the second temp folder in the preference, I was working with the prep folder only not the temp folder.
