Multicam Problems while editing
I have read and re read the instructions and I must be missing something. I have a 2 camera project i want to work on in Vegas ver 8.0
I have both clips in the project media then i go TOOLS>MULTICAMERA>ENABLE MULTICAMERA>LAY OUT TRACKS USING MEDIA TIMELINE When i try to drag the seperate clips to the track all that is showing up a is a little sliver of the video, what am I doing wrong? These are large clips like 5gb in size Thanks.... Dave
Vegas 8.0c (Build 260)-(Upgraded to Sony Vegas 10 pro)Canon GL2, Canon HV30, HF200, HF20-Sony UWP Wirelesss Mic Kit, Intel Core 2 CPU-6600@2.40GHz-3.00GB Ram |
David,
drop all your footage from one camera on track 1, second camera on track2. sinc the two tracks so they are timed how you want them. I prefer to use an audio spike from the wave form if they have similar audio, ( I always use a strobe when I film as a back up). Once you have done this then enable multicam. you will be ready to go.
DATS ALL FOLKS Dale W. Guthormsen |
be sure to select the tracks before starting the multicam track.
#5 |
Sponsor: JET DV
Many people are making a copy of the original tracks before they're combined for multi-cam so you can easily get back to the original tracks if needed.
Plus, remember the script multi-cam options are certainly still viable. Using the scripts has some advantages and using the built-in one has some advantages.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
