Vegas Vs. Final Cut Pro - Page 3 at DVinfo.net
Old March 22nd, 2004, 07:58 PM   #31
(1) All effects (audio and video) can be automated. But I *hate* the timeline that appears in the clip window where you can access and manipulate effect parameters over time. It's an inteligent way of representing what's going on, but it's very difficult to work with because the segment of time you see is so small and the vertical axis on which you can move the parameters is also quite small and difficult to manipulate because of that. Perhaps there is a way to make it larger but it's not obvious enough for me to figure out.
For the general clip window, there is a slide bar at the bottom of the editing window that you can grab with your mouse and drag left, to space the clip out...I think you can look at every frame in the video if you so desire.
You can also go to the edge of the track ( on the left hand side, where they are numbered 1,2, 3 etc...) go to the bottom edge and grab the line between the clips with your mouse....drag it down and it will increase the size of that track so you can see what it is your editing
I think that is what you were asking about, or stating rather.
Rives Elmore is offline   Reply
