Text distortion at DVinfo.net
Old April 20th, 2009, 06:40 AM   #1
Text distortion
Two questions:
Below is a link to an image that shows how messed up my text looks in Vegas on a black background. Usually if I change fonts it works out fine, but not this time. this was rendered to .avi widescreen, and frame size of text is 1440x960.
Here's photo:
http://www.dvinfo.net/conf/members/j...3-capture.html
Question #2:
How do you embed/put a photo in a post? I've seen others do it, but I'm flummoxed.
Old April 20th, 2009, 03:08 PM   #2
Is this text zoomed in or did you use a large size font?
Try addding a small black outline to the text.
Puttin the wet stuff on the red stuff!
Terry Esslinger is offline   Reply With Quote
Old April 20th, 2009, 03:12 PM   #3
That is not zoomed in, that is the actual size. I did darken the white to a light grey, and that helped. I'll try your suggestions also.
Thanks Terry.
Old April 20th, 2009, 05:35 PM   #4
Sponsor: JET DV
Also, change the text display to double resolution.
Old April 20th, 2009, 07:09 PM   #5
Actually what you see is double the resolution, I have also tried it tripled, it's the same.
Old April 20th, 2009, 07:39 PM   #6
Hi Jeff,
I had the same exact problem, changed the properties to HDV 720-30P problem was solved.
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e
Matthew Amirkhani is offline   Reply With Quote
Old April 20th, 2009, 07:47 PM   #7
Jeff, you said you changed the text to a light grey and that helped.
I make it a rule to never exceed 235-235-235 for white text (and 16-16-16 for black) and don't recall ever having this problem.
These values ensure that text says within the 16-235 luminance range.
Old April 21st, 2009, 07:06 AM   #8
Well Mike, it would appear that you have validated my experience. Thanks.
Old April 21st, 2009, 07:47 AM   #9
You're welcome Jeff.
I can't remember where I read those values but it's something I stick to and, as I said, have never had problems by doing so.
BTW, I've found Great Titles with the DV Codec to be an excellent article on the subject.
Old April 21st, 2009, 07:51 AM   #10
Those values seem perfect. Titles are still white but no issues now. Thanks for the link!
Old April 22nd, 2009, 02:02 AM   #11
Excellent article, Mike. Thank you for posting the link.
Ian Stark is offline   Reply
