#151 |
oops.. the link was down n its ok now.
#152 |
So it's the 11th. Has anyone received their confirming email yet?
Bob T. |
#153 |
not me......
edit. just noticed they bumped the date to tomorrow... |
#154 |
Delivery date has been changed to 5/12 according to website.
#155 |
It can't be, i've got it right now on my pc, the trial version.
Paul.
Round 2 GH5,FZ2000 |
#156 | |
Just received:
Bob T. |
#157 | |
I just downloaded my copy. Danny Fye VidMus Video - Music Productions
www.dannyfye.com |
#158 |
I got the same email and downloaded mine. I am beginning to install. I was surprised to see that it comes with DVD arch version 5.0b which I already had from my V8 upgrade but here goes...i'll be back after install.
I am back-installed and registered. It will take several weeks to give it a good test run but i am impressed with the options. If I already had NewBlue FX sampler, I would probably already have a lot of the new transitions and FX that came with that but for me this looks like a good investment at ~$185US.
3x-HD1000u - Ikan 8000HD- custom i7 PC - Vegas Pro 13 and 11 64 bit - Premiere Pro CS4 - and a whole mess of other equipment... Last edited by Bryan Daugherty; May 11th, 2009 at 11:02 AM. |
#159 |
Updates on opinions?
Hello friends! I am sad to report that I had a mission critical job appear around install time. I duplicated my project folders and eagerly imported into 9.0 and the playback was atrocious. It seems to automatically override your playback setting to what it perceives as "optimal" and in my case, the result was unacceptable. I reverted back to my 8.0 project file and finished the project. I did take all the files back into 9.0 for [b]batch[b] rendering with excellent results. I was disappointed that the chapter markers did not embed but it was nice to start the rendering before heading off to bed and get an 8 hr (okay, really more like 6hrs) head start on the process. I am glad for my investment but very ready for an update.
A quick note on unattended batch rendering. Make sure you disable scheduled virus scans and disconnect your internet. On my first attempt, windows and adobe both downloaded updates in the background and as they tried to extract themselves it froze my render, locked the computer and I had to shut down...worst part? I was rendering with a 2 pass encode from HD source files and the crash happened on the second pass about (estimated) 30 minutes before finishing and the entire render had to be redone... So what does everyone think of the upgrade thus far?
3x-HD1000u - Ikan 8000HD- custom i7 PC - Vegas Pro 13 and 11 64 bit - Premiere Pro CS4 - and a whole mess of other equipment... |
#160 | ||
Sponsor: JET DV
http://www.jetdv.com/scripts/BatchRender5.cs Then look for this line: args.IncludeMarkers = false; Change the false to true and the markers will be included.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#161 |
Bryan, disable the automatic adjustment feature of preview (as Edward mentioned) by right-clicking anywhere in the preview window and unchecking "Adjust Size and Quality for Optimal Playback" and you can come back to Vegas 9 if you want to.
We had a thread (that has been closed) where people were discussing Vegas 9, and the reaction of most of the folks that weighed in seemed to be negative, mainly for playback issues. In my case, AVCHD files playback far worse in Vegas 9 64 bit than 32 bit. And they definitely playback better on version 8.0c than version 9 32bit. Others are finding it works fine for them. I suspect that the upgrade just isn't as compatible with some configurations as with others. I have found myself using vegas 8 as the preview performance just isn't the same with 9 for me. Many of us are hoping that upon the first "fix" will remedy this problem. |
#162 |
Thanks for the thoughts guys, I also found the playback issues even when it was not overriding my settings. It just streams smoother in 8.0...I hope the update correct this and hope to see it soon. I saw your other thread after starting this up again and it looks like it got pretty ugly in there. I hope I am not opening a can of worms posting this here. The thread I saw had been sanitized so hopefully people have cooled off and will keep it civil.
Edward, I will look into your script, thanks! I am generally wary of scripts from msg boards but you come with trust from your status on this board. I have a DV project coming soon, so i am looking forward to flexing 9.0 again with SD files this time...
#163 |
Bryan there are actually many great scripts floating around for Vegas.
#164 |
yeah I have heard of many and downloaded a few. But I am pretty close to paranoid when it comes to viruses so I am often wary of downloading anything from a stranger. Mostly because (like you) I built my own system so if I screw it up there is no tech support to call. I played around with V9 a little more last night but I am still having playback issues. It seems to either use more processor/ ram then V8 which hurts playback or the code just hasn't been tweaked enough to playback as good as V8. I am still running my core2quad and haven't taken the i7 plunge yet, to many other capital expenses this year. I like the New Blue pkg too but haven't found a good use for it yet. I have been looking pretty intently at the Production Assistant software too. Did you guys order it? What do you think of it, if you did?
#165 |
I didn't order it, but that doesn't mean anything because I haven't studied it much nor have I heard any glowing reports. You might start a thread with the PA question.
I have Ultimate S, and I don't really need much more, though I am always open to new tools. The list of features for Production Assistant sounded so similar to Ultimate S it seemed to be reduntant to purchase. If I had an unlimited budget I would have it just to check it out, but I don't so I won't. |
