Quick reference: Vegas shortcuts and mouse gestures 1.0b - Page 3 at DVinfo.net
Old October 11th, 2004, 03:04 AM   #31
RED Code Chef
A new tip
A friend of mine found out that you CAN see the original date and
time your footage was recorded (from the DV file) if your camera
saves this! As some may know besides time code extra information
like date and time (which is used to automatically split files during
capture for example) is also present inside DV files.
To view this information in your project do the following:
1. go to your media pool
2. select views -> details (the little icon above the media pool with a little grid and an arrow pointing down, click on this little arrow)
3. now the mediapool will change to a column view.
The third column from the end is "Date/Time Stamp" which is the
date/time the DV camera gave to the file.
I've never seen anyone mention this and a couple of people have
asked about showing this extra information. Now you can in Vegas!
This has been tested and confirmed in Vegas 5 only.
Rob Lohman, visuar@iname.com
Old October 11th, 2004, 08:59 AM   #32
Images: 10
wow!!
thanx
Old October 11th, 2004, 11:53 AM   #33
Old Boot
. . er . . it is there vegas 4 too?!? . . Where's the Fire? . . . BUT it would be neat to see on screen the camera's settings? I can get this from my XM2 . .
Grazie
Old October 14th, 2004, 04:55 AM   #34
RED Code Chef
Grazie: I just indicated that I didn't test this under version 4. So
I didn't know whether it is there or not. Glad to hear it is there
as well. I just didn't know about this trick.
Unforunately extra information is not visible. I've done quite a lot
of research into how the extra information is stored in the file
and it appears that:
1. there is a central place
2. the manufacturers can choose how to store certain information
So it is unknown whether extra information like shutter speed,
iris and other settings are using the same identifiers and scales
accross manufacturers (doubtfull).
Old October 14th, 2004, 05:37 AM   #35
Old Boot
Apologies Rob . . .
Yeah, pity I can't "see" this info. without pumping out from my XM2 .. .
Grazie
Old January 30th, 2005, 08:32 AM   #36
RED Code Chef
Color correction tutorials:
http://www.wideopenwest.com/~wvg/tutorial-menu.htm
Old April 28th, 2005, 11:36 PM   #37
In the official Sony forum, there's a thread about "EDITING FEATURES IN VEGAS YOU MIGHT NOT HAVE FOUND"
LINK: http://mediasoftware.sonypictures.co...lies=12&Page=0
I learned a few useful ones such as the Vegas equivalent of slip and roll edits.
Hold "alt" to get slip edits. ALT while mousing over a clip... drag left/right to slip
ALT over a transition edge to slip trim the transition.
"crtl+alt" gives Vegas equivalent of roll edit.
Glenn Chan is offline   Reply
