audio busses in Vegas - Page 2 at DVinfo.net
Old February 2nd, 2004, 02:03 PM   #16
Hey, wow. I get it now. You guys are awesome. Again.
Thanks all.
Marcia Janine Galles is offline   Reply With Quote
Old February 4th, 2004, 12:02 AM   #17
"Peter, I don't understand why you are saying to add a bus instead of just placing the volume envelope on the audio track. Either way requires a volume envelope somewhere to dynamically change the volume."
your totally, right, however what im referring to is a split your track into an indivdual outputs by using busses.
Basically assign a sound to a track, assign the track to a bus (which can then be rubber banded like a normal volume automation), route that bus to an output within the mixer, add your effects and voila...
this bus can be routed to any 6 audio channels, and is a good way for LFE manipulation :)
hope this made my post a lil clearer.
Peter Jefferson is offline   Reply With Quote
Old February 4th, 2004, 02:58 AM   #18
Well Peter,
A few things are unclear - to me anyway:
Splitting the track - does that mean you are keeping one signal intact and then sending one to the bus?
What is rubber-banding (in this context)?
What mixer are you refering to, an external one?
What is LFE (manipulation)?
Tor Salomonsen is offline   Reply With Quote
Old February 4th, 2004, 03:57 AM   #19
RED Code Chef
LFE is low frequency effects. Or the "bass" channel in surround
(ie, the .1 in 5.1).
Rob Lohman, visuar@iname.com
Rob Lohman is offline   Reply
