16 X 9 letterbox mask at DVinfo.net
Old January 21st, 2004, 03:39 AM   #1
I've downloaded the .png letterbox mask at: http://www.indigipix.com/videotips.htm
Video render for NTSC works great....however, if render for web-based playing, and viewed with windows media player, the very top and bottom of image sometimes bleeds though no matter how I adjust the crop....
any thoughts?
Mark A. Foley is offline   Reply With Quote
Old January 21st, 2004, 03:50 AM   #2
Old Boot
Hiyah! When you say "bleeds" through, do actually mean bleed OR do you actually "see" the other image?
Grazie
Old January 21st, 2004, 04:17 AM   #3
Old Boot
Ah yes . . I've just repeated the "bleed". I'm using PAL . . but I do get the video appearing above and below in Windows Media PLayer . . I understand. Have you tried NOT using the PNG and just using the Vegas widescreen format? I've done this too and although I've then sent the signal out to my monitor - a standard 4:3 tv, I do get it to work . . I've just now played this same Vegas widescreen without using the stretch video option, and it appears to work in WMP . . . so no use of the png and let Vegas do it - yeah? Try it out, just to confiem I ;ve got it in the "Ball Park" - yeah?
Grazie
Old January 21st, 2004, 05:47 AM   #4
Grazie...
Don't you get distortion of the original 4:3 video when using Vega's 16 X 9 preset?
Old January 21st, 2004, 05:58 AM   #5
RED Code Chef
Take a look at my 16x9 letterbox calculator, I've also put up the
most common masks for everyone to download. They seem to
work fine for me.
Everybody seems to be using different calculations to get the
size of the mask. My formula and reasoning behind it are pretty
well explained on the page.
Rob Lohman, visuar@iname.com
Old January 21st, 2004, 06:01 AM   #6
Old Boot
Absolutley Brilliant!!
Rob you ARE the star . . Great stuff . .love it . .I'm off to try it out . .
My best regards,
Grazie
Old January 21st, 2004, 06:03 AM   #7
Rob,
I'm in the middle of another project right now, otherwise I would try your mask....
Have you tried yours with rendering out to .wmv? to see if it does fully mask?
Old January 21st, 2004, 06:03 AM   #8
RED Code Chef
I just changed the link to point to my new site since the other
one will be going away soon. Make sure you follow the latest
link.
The calculator is also going to be updated in the coming month
or so with some additional calculations and changes to the
javascript to make it more compatible and less buggy.
Old January 21st, 2004, 06:08 AM   #9
RED Code Chef
I didn't check it out with WMV but did with MPEG and full DV
output. As far as I know they are watertight. Do MAKE SURE
you are importing these masks wtih a SQUARE PIXEL (1.0)
aspect ratio (default on any NLE I've seen). So don't change it
to DV aspect ratio. My calculations already used the pixel aspect
ratio and therefor don't need any correction in the NLE.
Mark: maybe you can just check it out on a little scene in a new
test project? Render it out to WMV and let me know how it goes.
We did use my calculations for the Lady X project as well.
Old January 21st, 2004, 06:25 AM   #10
Bingo Rob...that was it...luckily I had some footage from my other project that I had tried another mask with....your mask worked perfectly....
If I see anyone else asking about this subject on other boards/threads, I'll direct them to your website....
Thanks....
Old January 21st, 2004, 06:31 AM   #11
Old Boot
Mark . . just posted a link over at the Vegas site . .okay Rob? - Just thought it was too good not to share.
Thanks again,
Grazie
Old January 21st, 2004, 06:46 AM   #12
RED Code Chef
Sure, as long as you used the new link:
www.visuar.com/letterbox/calc.htm
Old January 21st, 2004, 07:17 AM   #13
Old Boot
Yup, just checked - someone visited your site already!
Thanks again Rob.
Graham Bernard is offline   Reply
