Does Vegas Play Nice With After Effects? - Page 2 at DVinfo.net
Old December 18th, 2003, 10:59 AM   #16
Sponsor: JET DV
In that case, yes I would use AE! It's hard to beat "already own". And the two will work fine together - just not integrated.
Old December 23rd, 2003, 04:02 PM   #17
Another workflow option:
1. Frameserve from Vegas to After Effects using Satish's free Plug-in Pac (www.debugmode.com)
2. Build composition in After Effects
3. Render out as uncompressed (or lossless codec like HUFFYUV) video.
4. Reopen rendered video file in Vegas as needed for final cut.
Unfortunately, there's no way to frameserve OUT of After Effects, and Vegas DV Codec is not accessible to any program other than Vegas.
But I've used this method quite successfully with Vegas and AE.
Brian Standing is offline   Reply With Quote
Old December 28th, 2003, 11:22 PM   #18
for Edward Troxel
I just read an article on the Watchdog pages by Daniel Broadway about simulating a 35mm motion picture clarity signature. Given your knowledge of Boris Red, I wondered if you could answer some questions for me.
Do you know if the "formula" he used in After Effects would be pretty much the same in Boris Red? It sure would be nice accessing BR from the Vegas timeline.
Here's the link to the article if you need it: http://www.dvinfo.net/articles/filmlook/broadway1.php
This is veering off-topic, but I've also read a little about Magic Bullet and seen some great footage on the Web (though we're looking at output to DVD). Could the end result of Mr. Broadway's technique and Magic Bullet be similar?
Thank you, in advance, for your help!
Old December 29th, 2003, 02:31 AM   #19
I've been doing some messing around in Vegas, and it looks like it has a strong set of tools to give you control over your image.
The typical brightness, saturation and contrast filters in just about every NLE and image editing program aren't that good. The curves filter in Vegas and the saturation adjustment filters offer much better control!
Getting more "contrast" out of your image:
Use the curve filters and look through the presets. The "contrast" preset gives the same effect as the normal contrast filters in every program. You can do better. Make the curves look like an "s" (it's in the "Simulating 35mm Motion Picture Color Saturation" article you mentioned). This simulates the "soft shoulders" inherent in film, and also happens to make your image look more contrasty.
Saturation:
Use the saturation adjustment filter instead. It's like curves except for saturation. Try boosting up the lower end more than the highs. Some films have this characteristic (colours get more saturated in underexposure).
White balance:
Film white balanced for daylight will turn out yellow indoors. I forget the exact way of getting this effect with curves. If you know how to use curves in Photoshop you know Vegas' curves. Boosting yellow involves boosting the red+green channels so they are concave and look like a hill. You want to boost the red+green channels because red + green = yellow.
You can get great results once you master Vegas' color correction tools. The most useful ones seem to be curves, saturation adjustment, 3-way color corrector, and the secondary color corrector.
Effects:
You can also apply soft focus and film grain (not to be confused with video noise!) with Vegas. Vegas' film grain filter is good for film grain (I don't know any better ones). Soft focus you achieve by duplicating the video onto itself, blurring the top with gaussian blur, and lowering the opacity of the top clip. There are a whole bunch of other things you can do with the duplicating video onto itself trick.
Old December 29th, 2003, 03:06 AM   #20
Thanks, Glenn--that's a lot of good info! I had read the trick about soft focus before but forgotten it, so this time I'll print what you wrote and start practicing.
Appreciate you taking the time to give detailed tips/explanations. They'll help a lot.
Lorinda
Old December 29th, 2003, 10:01 PM   #21
http://www.freewebs.com/vegas4/vegas4.htm
More ideas there :)
Old December 29th, 2003, 11:06 PM   #22
Gosh, I'd forgotten how much I miss Alex K. (haven't *seen* him around here in quite a while). Quite the talented young man, plus good for a laugh. Loved that quip at the bottom. :)
Thanks; I'll practice from that tutorial as well.
Lorinda
Old December 30th, 2003, 10:47 AM   #23
Where is the best place to read up about Boris Red? Also do all new versions automatically support Vegas or is there a specific version made for Vegas?
Oh yeah- I was wondering where Alex has been myself. Haven't seen him post in quite some time. Think the last post was around Sept. Guess school is keeping him really *busy*.
Glen Elliott is offline   Reply With Quote
Old December 30th, 2003, 11:40 AM   #24
Sponsor: JET DV
Only the latest version supports Vegas. I suppose the BEST place would be at BorisFX.com and/or the manuals.
Currenlty, Vegas is supported by:
Red 3GL
Graffiti 3
FX 7
Edward Troxel is offline   Reply
