Partitioning NLE for Vegas - Page 2 at DVinfo.net
Old April 12th, 2009, 01:05 AM   #16
Originally Posted by Ricky Kua View Post
How about vegas temp folder and dvda temp folder and os pagefile? everything in C drive is ok?
Yes, that is fine, but you might delete the files in your DVDA temp folder after use. I personally put the DVDA temp folder anywhere where I will see it so that I will remember to delete it and keep it from cluttering up my drive after the project is over.
Old April 12th, 2009, 01:21 AM   #17
Thanks mike. Most of my problem should be solved. Now all i need to do is to find if there is
any reseller in Malaysia cause my company have difficulty buying things oversea.
Ricky Kua is offline   Reply With Quote
Old April 12th, 2009, 07:07 AM   #18
Ricky, as I said earlier, all of this gear is commonly used by TV stations so, if you have one nearby, check with their chief engineer as I'm sure he/she could steer you in the right direction.
Old April 12th, 2009, 12:54 PM   #19
Originally Posted by Jeff Harper View Post
Jack, it is true that having the page file on a separate drive is nice. On the other hand, I don't think with his limited number of drives it is necessary.
It's still better to put the pagefile on a drive separate from where the OS is so that both processes aren't trying to access the same drive simultaneously.
Rick Diaz is offline   Reply With Quote
Old April 12th, 2009, 02:00 PM   #20
Didn't say it wasn't better Rick. It just isn't that worth it when he only has four drives. I wouldn't waste one out of four 15K SAS drives on it. The performance increase with Vegas is so slight, as its use of virtual memory is not that heavy to begin with. I run without a page file half the time, and see virtually no difference either way.
Old April 12th, 2009, 07:51 PM   #21
I guess if one ONLY uses their computer to run Vegas then your statement makes sense, but since most people do other things with their PCs that often does utilize the pagefile it is probably better to place it on another drive. I am not speaking to the specifics of those 15k SAS drives, but in general terms that fit most users. ;)
Old April 17th, 2009, 07:19 AM   #22
Guys 've opened a thred hoping to have a succesful input from my gurus of pc config;Please don't get mad but if u'd have just 2 minutes to check that thread i'll be very thankful!
Sorry and thx
Marcus Martell is offline   Reply
