splitting audio track at DVinfo.net
Old April 9th, 2009, 07:30 PM   #1
Good evening,
this morning I was shooting with my xlh1. I ran a shotgun mic on xlr 2 and the front mic on channel 1.
I was getting enterior noise from my blind on channel 1 so I turned it down to zero.
On my time line I have a wave form for channel two but I do not get any audio.
How can I seperate them so I can use the existing audio that shows the wave form?
I have a program that does this to SD but it wont work on HD.
can Vegas do this??
DATS ALL FOLKS
Dale W. Guthormsen
Old April 9th, 2009, 07:59 PM   #2
Yes. Right click on an audio clip, pull down to Channels, select Right Only.
Copy this event, select all your other audio events that you want changed, right click on one, and pull down to Paste Event Attributes. That will essentially convert the audio track to mono, using the Right ch. of the original source. The original captures are not affected by this.
Old April 10th, 2009, 12:32 PM   #3
Seth,
Thank you for the easy and quick fix!! I copied the audio track and applied a second duplicate track, Pretty nice!!!
thanks again!!!!
DATS ALL FOLKS
Dale W. Guthormsen
Dale Guthormsen is offline   Reply
