Vegas Video discussions from 2004 (Q1Q2) - Page 84 at DVinfo.net
Old April 13th, 2004, 09:31 AM   #1246
Sponsor: JET DV
Yes, those are possible. You need to get comfortable with masks and keyframes. With a mask, you can easily cut out a small section of a video. With keyframes, you can track the motion of that section.
As for training materials:
My newsletters http://www.jetdv.com/tts
Gary's DVDs http://www.VegasTrainingAndTools.com
Spot's DVDs & book (available at various locations)
VASST training tours http://www.vasst.com
etc...
Edward Troxel is offline
Old April 13th, 2004, 09:39 AM   #1247
Thanks guys!
Hydravision runs great and has made things a lot easier!
Sunny Dhinsey
Director - www.filmlore.tv
Sunny Dhinsey is offline
Old April 13th, 2004, 09:40 AM   #1248
Artistic color correction. Can be done with the color corrector.
Glen Elliott is offline
Old April 13th, 2004, 09:46 AM   #1249
Edward...will Vegas 5 be worth the upgrade?
I ask this knowing you are into wedding videography as I am myself. Are any of the new features helpfull for this genre...better yet- $300 helpful?
I see ads now for Vegas+DVD, new additions in Vegas that are touted are:
-3D motion and compositing
-Keyframable bezier masking (???)
-Control surface support (???)
-Evelope automation recording (???)
-Auto-input record monitoring
-Film-style 5.1 surround panning (???)
-Real-time A/V event reverse (wonder if they fixed the problem where you can't reverse spliced clip)
-Media Subclip creation (? Similar to Premiere's Virtual Clips ?)
-Customizable keyboard mapping
-Networked rendering
- and much more ( ???)
Old April 13th, 2004, 10:11 AM   #1250
i honestly think it will be with the 3d motion and compositing alone...
this is combustion style tools were talkin about.. all in one package...
film style surround is something im also curious about though...
Peter Jefferson is offline
Old April 13th, 2004, 11:06 AM   #1251
Sponsor: JET DV
Yes. Look for more information very soon.
Old April 13th, 2004, 11:07 AM   #1252
Sponsor: JET DV
Where are the ads you are seeing?
Old April 13th, 2004, 11:36 AM   #1253
Ad on the back of the May issue of Digital Videomaker.
It's an add for Vegas+DVD "production suite"- which also lists some of the new features in DVD Architect 2:
-End actions (woo hooo!)
-Multiple audio tracks (where's mutliple camera angles!)
-Subtitle support
-24p DVD encoding (that's ALREADY supported?!)
-Elementary Stream Import
-Project overview window (???)
-Real-time external monitor previews (nice!)
-And much more (???)
Old April 13th, 2004, 01:27 PM   #1254
RED Code Chef
Good you have it solved. The problem most likely isn't Vegas at
all since I can't see why it would need Terminal services for it
to run. But Vegas is probably using some component of Windows
that does require it to run. So there you have it.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old April 13th, 2004, 01:42 PM   #1255
Sponsor: JET DV
Quote from SonyDennis:
Vegas supports Windows XP "Fast User Switching" and this uses "Terminal Services".
Old April 13th, 2004, 02:11 PM   #1256
RED Code Chef
Thanks for that Edward! We learn everyday here <g>
Old April 13th, 2004, 03:19 PM   #1257
Hi,
I see Glen mentioned a few possible features of DVD Architect..I am a bit of a novice to authoring.. Have done a few with Architect 1.. Can you give an explanation of end actions??And maybe an example of using multiple audio tracks??
thanks,
Mike Moncrief
Mike Moncrief mikemoncrief@gmail.com
www.themikemoncrief.com
Mike Moncrief is offline
Old April 13th, 2004, 03:31 PM   #1258
Sponsor: JET DV
End Actions allow you to specify what will happen when a process "Ends". For example, right now if you have three small MPG files and make a DVD in DVDA, you will get the first one to play and it will return to the menu. You can play the second one and it will return to the menu. With end actions, you can specify that the first one is to play and then, when it is finished, the second one is to play.
Multiple audio tracks can be useful when you want to put out a DVD with English and Spanish voices, for example. Or maybe you want the standard sound track and a "commentary" track.
Old April 13th, 2004, 04:04 PM   #1259
RED Code Chef
Shortcuts etc.
Old April 13th, 2004, 05:01 PM   #1260
Sweet -- bezier masks, subclips and network rendering. Everything but the kitchen sink, apparently.
I know my pennies are saved :D
- jim
Realism, anyway, is never exactly the same as reality, and in the cinema it is of necessity faked. -- J-L G
Jim Lafferty is offline
