#933 |
Thanks Edward,
The spot is a 30 second advertisement that will be projected from a PC using Power Point at a local theater chain. Installing the MPEG2 codec might not be an option in this case (not sure how many theaters as of yet). Would MPEG1 be acceptable in this use? I did notice some serious degredation when I rendered it to mpeg1. My last moronic question; where would I get the MPEG2 codec? Is it on my Vegas CD? (I should know this, huh) |
#934 |
RED Code Chef
Edwards suggestion is excellent. This is exactly what I did for my
Lady X episode. I put a mask on one track above everything else and almost every scene has been moved slightly lower or higher underneath this mask with pan/crop tool. Works PERFECT. Perhaps you've accidentily keyframed something?
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#935 |
That's interesting. I've been asked to investigate embedding a small segment of video in a PowerPoint presentation that will be distributed around the client's business partners - all of whom are using PowerPoint but with almost inevitable system differences.
Is there a "safe bet" format that would offer the highest probability of successful playback from PowerPoint/different versions of Windows etc? |
#936 |
RED Code Chef
No it isn't on your Vegas CD. Most MPEG2 codecs in use today
have been installed by a software DVD player like WinDVD or PowerDVD. MPEG1 should be supported on all systems out of the box. It does have a bit lower quality indeed. Not much around that I'm afraid. You might try increasing the bitrate a bit.
#937 |
Thanks Rob. Experiment time!
It will be run from a CD/hard disk anyway so size isn't an issue. |
#939 |
Can someone repost Edward Troxel's 24p conversion Film Look plugin?
Just what it says. I'm in a rush and a director friend of mine needs to make her music video she shot for a NYC band on a Panny DV953 to look less videoie and more 24pish. The thread only has a broken link for the script now.... thanks in advance!
#940 |
Sponsor: JET DV
It's still there. You may be looking at an OLD link. Here's the current link:
http://www.jetdv.com/scripts/RC3_VegasFilmLooks.exe |
#941 |
how to mask 4:3 for 16:9?
HI,
I just purchased DVXA Pal! 1) Anyone can tell me how can I be sure how much should I mask 4:3 LCD screen for 16:9? 2)Does Vegas have this 'drop" option? Thanks for help, Voytek
voytek |
#942 |
Picture to video problems with Vegas 4.0
I resized my pictures to 655 X 480 and when I watch it on TV it cuts off some of the picture. When I watch it on my computer I can see the whole image. I know I don't have the same res on my tv that I have on my computer but I must be missing something. I have a plasma tv and a normal analog tv and it cuts it off on both.
Any ideas would be helpfull. Thanks, Jon |
#944 |
Thanks so much Edward, I guess I was looking at the old link! We can make the rush to fedex this puppy off today now. Cheers!
#945 |
Edward,
Thank you for the tip. I fit my picture in the square, outer square and it only cuts of a tiny part of the photo. If I reduce it to the inner square it shows the whole picture but has extra room. Is there a size that will fill the whole tv screen? I have played with the safe area to try to get it fill the whole frame with no success. What book would you recommend for a how to on vegas 4.0. Thanks, Jon |
