Vegas Video discussions from 2004 (Q1Q2) - Page 61 at DVinfo.net
Old March 20th, 2004, 04:54 AM   #901
You basically have two choices:
1. Pan and Scan: http://en.wikipedia.org/wiki/Pan_and_scan
2. Letterbox it
I've never done it but I think you could use track motion to pan and scan. It might be a bit tedious.
Letterbox would certainly be the easiest - do a search here, should be lots of posts on technique.
Jerry: Photography • Video
www.takeonesolutions.com
Jerry Norman is offline
Old March 20th, 2004, 05:46 AM   #902
http://mediasoftware.sonypictures.co...ssageID=257603
Check the links within the posting above for some additional advice.
I can't advise on the drive you mention but I CAN tell you that I have a problem with my WD 250Gb drive conflicting with my Canon GL2/XM2 (different sources suggest the camera or the drive)
Ian Stark is offline
Old March 20th, 2004, 05:59 AM   #903
RED Code Chef
Voytek: that's the same drive I have. Both USB2 and firewire
seem to work fine. I did find the drive a bit slow, but I'm not sure
if this is the drives fault or my firewire / USB connections (I can't
do an accurate USB test since I only have USB 1 here).
It has worked great with Vegas and all of my DV work.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old March 20th, 2004, 06:20 AM   #904
Sponsor: JET DV
<<<-- Originally posted by Peter Jefferson : or a more efficient way might be to let it run on left...
then run the onboard mic on ch2...(right) -->>>
When I do this, I'm recording 4 channel: Stereo 1 = on-camera mic and Stereo 2 = Wireless (Y'd to both channels). Sort of the "best of both worlds"
Edward Troxel is offline
Old March 20th, 2004, 05:12 PM   #905
how can I make the sound morph with slow-mo?
when I do a velocity envelope to make a clip slow motion the sound says at the same rate, how can I make the sound slow as well?
thanks
The glory of the World passes by.
John Gaspain is offline
Old March 20th, 2004, 10:26 PM   #906
Rextilleon
Not sure what you are looking for but there is a time stretch in the audio fx package----keep it between 75% and 115% and you shouldn't have a problem. Hope that helps.
David Mintzer is offline
Old March 20th, 2004, 10:45 PM   #907
Ill give that a try!
thanks
Old March 21st, 2004, 12:55 AM   #908
EXACTLY!!!!!!
and it works fine too :)
Peter Jefferson is offline
Old March 21st, 2004, 01:09 AM   #909
Sponsor: JET DV
Audio does not have a velocity envelope similar to the video. However, you CAN change the speed assuming you want ONE constant speed change. Hold down the CTRL key are resize the event.
Old March 21st, 2004, 09:48 AM   #910
anyone doing Vegas in Denver Co
Would like to get some help on some stuff I'll buy lunch..
Vince
Vince Debart is offline
Old March 21st, 2004, 12:55 PM   #911
Sponsor: JET DV
You might want to look at my newsletters, Gary Kleiner's DVDs, DSE's DVDs and Book, and asking questions here.
Old March 21st, 2004, 03:12 PM   #912
Can you make CD using DVD Architect??
Hello,
Something I never have tried yet, but have wondered about, and now may have a need for.. Can I use DVD Architect to create a menu based CD(not a DVD) ??
It would have 2 buttons, one launching a picture slide show, and the other palying a piece of video that is 30 seconds long.. (surely this will fit on the much less capacity of a CD versus a DVD)
Mike Moncrief
Mike Moncrief mikemoncrief@gmail.com
www.themikemoncrief.com
Mike Moncrief is offline
Old March 21st, 2004, 05:18 PM   #913
Not exactly sure but I think DVD is the format you will have to wrk with not CD.
In other words you an do anything you want AUDIO wise but will still have to do it on DVD to be played in a DVD Player even if it is just Music.
John Hudson is offline
Old March 21st, 2004, 06:22 PM   #914
Thanks Edward ..You have already helped me I got another ILink card its working now
haning fun playing ...pretty cool to edit video on a 599.00 Dell
Vince
Old March 21st, 2004, 08:45 PM   #915
Sponsor: JET DV
DVD Architect cannot burn to CDs. However, there's no reason DVD Architect cannot create files small enough to fit on a CD. However, there's no guarantee that it will play in your player.
