Vegas Video discussions from 2004 (Q1Q2) - Page 48 at DVinfo.net
Old March 9th, 2004, 12:13 AM   #706
Temporary and Prerendered Files Folder question
First of all many thanks to Edward for the great job with the Tips, Tricks and Scripts guide!
I need to know more in order to make my choice on the hard drives usage and organization though.
What exactly is the Temporary files folder?
In Sound Forge the program makes back up copy so you can restore quickly the changes and the actual editing is on the copy. Obviously it’s better the temp folder to be on different physical disk. After you confirm the final save the original file is overwritten.
How is that implemented in Vegas?
Also what does it mean Prerendered files? I know that Vegas when told to render is actually skipping the untouched parts and rendering only the parts with effects and transitions, added text, etc. What is the relation between the raw DV data and the rendered final project?
Where the actual editing process take place? If it’s in the temp files folder than it’s better to be different from your raw video storage disk I think.
Often spelled tip says ‘keep your things not on your OS drive’. But usually main OS kernel and active programs are run from within the RAM (if you have plenty). So here there is controversy I guess.
My basic scenario will be:
1) Capture from mini DV
2) Edit (with Vegas for example)
3) Render the final project (ready for printing to tape for archiving on mini DV)
4) Encode to MPEG2 + AC3 (authoring for DVD). I would like to store this for certain time so I can make few copies later if needed.
What would be my best set up if I use only 2 drives?
Any opinions? Thanks…
P.S. You can omit my scenario – I’m really interested mainly on the physics of editing process!
Bogdan Vaglarov is offline
Old March 9th, 2004, 08:13 AM   #707
Sponsor: JET DV
The "Temporary Files Folder" is where Vegas will write any files that need to be temporarily created and then deleted when no longer needed. However, sometimes a large amount of space is needed so make sure the drive you choose has plenty of space. This CAN be your OS drive as long as the OS drive has plenty of room. Every time you render, temporary space is used.
The "Prerendered Files Folder" is where all prerenders are stored when you either manually choose to pre-render OR you do a Print To Tape. This should typically be your video drive and may also require a large amount of space.
Edward Troxel is offline
Old March 9th, 2004, 02:57 PM   #708
Convert Stills to slideshow
Does anyone have a nice way to take a pile of jpg's and turn them into a montage/slideshow with transitions in a somewhat automated fashion?
Kim Kinser is offline
Old March 9th, 2004, 03:04 PM   #709
Curious about Screenblast upgrade...
I have Screenblast, and I am considering the reduced cost upgrade to Vegas 4, which is $459. Of course, I could upgrade to Vegas+DVD and get the additional software, for $699. Therein lies my conondrum. I understand, in general terms, what the additional software in V+DVD is for. I really do not need the AC-3 audio, but it is pretty sweet I'm sure. Other than that, what are the benefits of the additional $250? Will finished products made in Vegas look "better" when burned to DVD with the +DVD software. I read that the encoding is better (I may really screw up my terminology here) with the apps in +DVD, which result in better audio AND video quality on the final DVD copies. If this is true I may stretch my budget and get the full-meal-deal. However, if I can create projects in Vegas 4 and move them to DVD that look the same in regard to quality, but have less options for chapters, or menus & buttons etc, I would rather spend the money on something else. If it isn't painfully obvious I am a newbie to this level of editing, so I appreciate your assistance as well as your patience.
It's not a bug, it's a feature.
James Sudik is offline
Old March 9th, 2004, 03:54 PM   #710
Sponsor: JET DV
The "+DVD" adds both the AC-3 encoder AND the DVD authoring program. You need a DVD authoring program to create the proper files to burn a DVD. If you already have a different authoring program you prefer to use, then "+DVD" is not required. However, I LIKE DVD Architect and now use it for ALL of my DVDs.
Old March 9th, 2004, 03:56 PM   #711
Sponsor: JET DV
Sure I do. Check out the article that talks about that in my newsletter.
http://www.jetdv.com/tts
The aid of a couple of scripts really helps speed up the process!
Old March 9th, 2004, 04:46 PM   #712
Thank you Edward!
So if I save my project on the video drive (with the raw data) it's clear the temp folder is better to be on different drive.
I still can't understand the difference between pre-render and render though.
Need a bit more clarification. Thanks.
Old March 9th, 2004, 06:02 PM   #713
update
So far, I've traced it to the point that the movie does not play once I've applied field blending (none: progressive) deinterlacing. The clip that does not have this process applied plays fine on all players.
Dan Lum is offline
Old March 9th, 2004, 06:33 PM   #714
I follow you. I have the authoring app, but it is low-end (Sonic MyDVD is it I think) and was curious if the higher priced +DVD software was woth it in regard to quality of the final image on DVD.
Old March 9th, 2004, 06:53 PM   #715
Pre-rendering is still, technically rendering, but in a different context to "real" rendering. You usually "Render" your project when you've finished it and want to write it out in whatever codec and format you need (MPG2, Sorensen, DV etc) for final distribution. "Pre render" is usually the bits of rendering you do during the editing process, prior, or PRE to the "real" render. For example.
You might want to Pre-Render when you've applied a complicated effect to a region on the timeline that you couldn't playback at full framerate. You can just select the region on the timeline and chose to Selectively Pre-render. That region of the timeline will be rendered to your Prerender directory. Now when you play the timeline that clip will playback as though it was fully rendered. It will be using the "Pre-rendered" clip you made previously.
Any changes to that area of the project though will discard the pre-rendered clip and you'll have to pre-render again.
Aaron
My Website
Meat Free Media
Aaron Koolen is offline
Old March 9th, 2004, 08:30 PM   #716
Sponsor: JET DV
Best I can answer is "It depends". Generally speaking, they SHOULD both be able to give the same quality. However, it depends on where you do the rendering (in Vegas in both cases? or do you let MyDVD render?) and whether or not the program will accept the MPEG2 files without re-rendering. Lots of factors can make the answer vary.
Old March 9th, 2004, 09:48 PM   #717
Did you mean the pbs wizard?
Thanks for your quick response btw.
KIM
Old March 9th, 2004, 10:58 PM   #718
Rextilleon
PBS is for the Ken Burns effect--read the newsletter Ed referred too.
David Mintzer is offline
Old March 10th, 2004, 01:49 AM   #719
James,
I'm a Vegas user who hasn't added DVDA. I use Movie Factory (a Ulead product) which cost me $50 and am very happy with it. I encode to the DVD template in Vegas using best quality and then import the MPEG-2 file into Movie Factory. No re-rendering. It burns with outstanding quality. If I need to, I can create some chapters but so far, I've only done one DVD with chapters. Most of my DVD's just start to play (no chapters). When I get rich enough (or Vegas 5 comes out), I'll probably upgrade but for now, I'm happy with what I have. Hope this helps.
Randy
Randy Stewart is offline
Old March 10th, 2004, 08:03 AM   #720
David -
I did read it and I thought he meant the pbs wizard so obviously I don't get it.
Maybe I looked at the wrong issue?
Issue #1 In this issue:
What is Tips, Tricks, and Scripts
Vegas Preferences - Part 1
What is Scripting
Fade the Selected Event In and Out
Issue #2 In this issue:
Creating a PIP using Track Motion - Part 1
Vegas Preferences - Part 2
Finding Tracks via Scripts
Issue #3 In this issue:
Creating a PIP using Track Motion - Part 2
Vegas Preferences - Capture Utility
Automatically Generate Lower-Third Titles
Issue #4 In this issue:
Creating a PIP using Track Motion - Part 3
DVD Architect Preferences
Beginner's Corner - Where Do I Start?
Add Movement to the Lower-Third
Issue #5 In this issue:
Capturing Snapshots from Video
Beginner's Corner - Capturing Video
Single Button Snapshots
Issue #6 In this issue:
Introducing: Excalibur
Beginner's Corner - Printing To Tape (PTT)
Slideshow to Markers Script
Issue #7 In this issue:
Preparing for DVD
DVD Bitrate Chart
Beginner's Corner - Beginning Editing
Authoring a DVD in DVD Architect
Issue #8 In this issue:
Creating a Motion Slide Show with Pan/Crop
Beginner's Corner - Timeline Details
DVD Architect - Positioning Menu Items
Issue #9 In this issue:
Editing Multi-Cam Events
Beginner's Corner - Changing the Speed of a Clip
Adding and Assigning Bus Tracks
Issue #10 In this issue:
A Quick-Start Guide to Vegas Editing
Tsunami - A Wave of Editing Tools
Creating an Audio CD
Beginner’s Corner - Navigating the Timeline
Resetting Pan/Crop via a Script
Issue #11 In this issue:
Doing A Color Pass
Beginner's Corner - Changing Opacity
Add Markers At A Set Interval Via A Script
Issue #12 In this issue:
Review of Vegas 4 Editing Workshop Book
Beginner's Corner - Scope of Effects
Blurring Faces a la "Cops"
Obfuscating and Encoding Scripts
