Vegas Video discussions from 2004 (Q1Q2) - Page 27 at DVinfo.net
Old February 12th, 2004, 02:34 PM   #391
Images: 10
rather than do it in realtime zooming, can't you do this with a few keyframes and a composited frame?
edit:[ event pan/crop button]
Bill Ravens is offline
Old February 12th, 2004, 03:10 PM   #392
RED Code Chef
So are you getting no surround or swapped rear & front? I've
heard of this (unrelated to vegas) once before. I forgot how
and why though. Are you going out through SPDIF when in Vegas
as well?
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old February 12th, 2004, 03:34 PM   #393
Thanks for all the replies.
Bill, I'm new to this stuff so can you expalin the mechanism of composited frame?
Donie
Donie Kelly is offline
Old February 12th, 2004, 04:10 PM   #394
Sponsor: JET DV
Donie, I'm still not sure I'm picturing the effect you're looking for. Have you looked through the standard transitions too? There's several that do zooming.
Edward Troxel is offline
Old February 12th, 2004, 04:16 PM   #395
Hi Edward
At the start of the shot (POINT A) the camera is zoomed away in the distance at some object.
Pull the camera back slowly (will be sped up in edit) and move to foreground subject (POINT B). By doing it slowly I'm guaranteed that I'll be in focus and have framed the person in the foreground correctly.
Now during edit I do speed up between point A and point B. At the end of point B the camera is in focus and framed correctly. If there was any focus loss just before point B the sped up footage will make it irrelevant.
The finished shot will look like a super high speed zoom from a far object to a near one in perfect sysn with no apparent loss of focus or framing.
Just a split second shot but can be quite impressive.
Donie
Old February 12th, 2004, 05:43 PM   #396
No, I don't know how to do that? (SPDIF out in vegas)
It could be me needing a AC3 decoder in vegas because when I render to AC3 files, load them into my dvd software player It works well, I just don't want to have to render out to AC3 and listen and change and render when I mix.
Andreas Fernbrant is offline
Old February 12th, 2004, 06:48 PM   #397
What If I Do *This* While Rendering
Must I leave the computer alone while rendering in order to avoid glitches? Or can I web surf? Play Winamp? Render another project by opening another instance of Vegas?
Dave Largent is offline
Old February 12th, 2004, 07:53 PM   #398
<There is a theme editor program available by Brian Barnes that will let you create your own themes.>
Edward, do you happen to know the link for this? When I did a search I got a whole lot of stuff on an athlete named Brian Barnes. Don't think it's the same, but ya never know.
p.s. Your latest newsletter is great as usual.
Marcia Janine Galles is offline
Old February 12th, 2004, 08:34 PM   #399
Sponsor: JET DV
While rendering, you can basically do anything you want. Browse the web, edit another project in another instance of Vegas, Render multiple projects in multiple instances of Vegas, Play a game.
Old February 12th, 2004, 08:43 PM   #400
Sponsor: JET DV
I took me a minute to search for it. However, you can download it from: http://www.briancbarnes.homestead.com
Old February 12th, 2004, 08:44 PM   #401
Sponsor: JET DV
<<<-- Originally posted by Marcia Janine Galles : p.s. Your latest newsletter is great as usual. -->>>
Thanks.
Old February 12th, 2004, 09:50 PM   #402
I would imagine rendering two projects would cut the
rendering time in half, right? I notice my CPU
usage during rendering is 96% to 99%. Suppose this
is normal?
The reason I asked this is because I notice Vegas
drops frames while capturing when another program
starts up. But how about with printing-to-tape.
Should printing-to-tape be run by itself?
Old February 12th, 2004, 10:42 PM   #403
Sponsor: JET DV
Capture and PTT should be done with no other programs or activities running. Rendering is a totally different animal. Feel free to do other things while rendering. Don't do anything else while capturing or printing.
As for rendering multiple projects at once, yes they will both take longer. However, it WILL allow you to set up multiple projects rendering, go to bed, and, hopefully, they would be all be done the next morning.
Old February 12th, 2004, 11:49 PM   #404
The one thing I try to do when rendering multiple projects is have different target drives for each. Otherwise, you are rendering slices of each project onto the same drive. This results if highly fragmented files.
Joe Sacher is offline
Old February 13th, 2004, 02:21 AM   #405
If you have a Hyperthreading PC you will notice that you'll get better performance doing dual renders than if you had a non HT CPU and tried to do two.
Aaron
My Website
Meat Free Media
Aaron Koolen is offline
