#271 |
Sponsor: JET DV
In my experience, DVDA has not been picky at all. I have an A03 so I'm limited to "-" media but it has worked with a couple different brands.
As for using another program to burn, yes that is very doable. Just add the Audio_TS and Video_TS folders created by DVDA into the other program and tell it to burn the DVD. I have, on occasion, used Prassi PrimoDVD to burn the folders created by DVDA but now use DVDA to burn almost all the time. |
#272 |
Oddly enough I find myself dragging the effect from the effects palette the the clip- not that I need the animated references for the various effects. Maybe a left-over habit from my Premiere days. lol
#273 |
OK, I tried one last time with the TDK in DVDA and it actually let me choose the device this time but the drive speed window was empty. I clicked 'finish' anyway and I got an, "Error 0x8004e0c8" which I am assuming is the missing speed setting.
So, I burned the _TS folders on the TDK disc with Roxio 6 and it worked fine. It plays in 2 of my 3 DVD players, the third being a first gen Toshiba that I didn't expect to play in anyway, whew! I bet it's my Plextor being picky & not DVDA. It sure was gratifying to see the finished DVD on my 36" TV. Thanks Don & Ed! Shane |
#274 |
Edward, thanx for your help... but I think I have logged the clips, and I think I have a device control enabled.
So I´ll write every step of what I´m doing to see if you see something I can´t. 1.- Open VEgas 2.- FILE -> CAPTURE VIDEO 3.- Name my tape, don´t capture clips now (DEVICE STOPPED) 4.- go to ADVANCED CAPTURE Device works just fine... I can control the cam from Video Capture with no problem. Can set in and outs.. capture them.. play them, go to specific timecode.. etc.. 5.- Select Timecode IN and OUT. 6.- Push LOG IN/OUT button. (the clip name on top changes to TAPENAME - Clip 001 and so). 7.- Repeat 5 and 6 as as many times as needed. 8.- TRANSPORT -> ADVANCED CAPTURE... and.... BATCH CAPTURE is grey. No batch capturing for me... I´m using a XM2, just in case there is an issue there. And reasking a little here.. Is there anyway to use a Text file or XLS or something to do a batch capture, without having to type in, or select each clip to capture????
Messenger Boy : The Thessalonian you're fighting, he's the biggest man I've ever seen. I wouldn't want to fight him. Achilles : That is why no one will remember your name. |
#277 |
DOH!
Never mind... my mistake, it must have been my younger years of excess passing a bill on what´s left of my brain...
I´ve been using VEGAS for more than a few months now, and I didn´t know there was a CLIP EXPLORER option on VIDEO CAPTURE... And I also didn´t have the AUTOMATIC MARK FOR BATCH CAPTURE thing selected... Mental notes: "F1 is my friend"... "Some people spend many hours making the help files.. SO JUST READ IT".... So thanx for your help.. I got it covered now.. you could just delete this thread and save me some public humilliation... One last thing.. What about the magic thing that will let me use a text file or a xls file to do the batch capture withou marking ins and outs manually?
#278 |
i've been having similar issues. i use nero to burn my DVDs after DVD-Arch preps it on a folder. but if i use DVD-Arch itself to burn anything, it's all blank, won't burn. i have the liteon ldw-451s DVD burner. i mostly use DVD-R.
bow wow wow |
#279 |
Not Recognizing 24p
Hey I have had Vegas for a half a year and i cannot figure out How come when i capture some of my video off my AG-DVX100 it tells me my video was captured in 29 frames a second instead of 24 or sumthing like that. Why is that? Is the picture degrading because of it?
#280 |
Any Plug-ins?
I am wondering how come there are not many plug-ins for Vegas. I have not seen any type of after affects or any special prgram as a plug in for Vegas. Sonic Foundry or shall i say sony has not created any type of after affects program thing for vegas 4.0. Why is that?
#281 |
Boris Red?
#282 |
speeding up footage
I noticed that Vegas "maxes out" when speeding up playback rate at 4.000. Is there any way to increase the speed? Thanks
#283 |
Options > Preferences > Editing > JKL shuttle speed. Set to max. You'll get x20 playback.
#284 |
Hrmmm for some reason im actually not getting faster speeds. am i doing something wrong?
I have a 25 second clip and cant get it down to faster than a 5 second clip w/ or w/out JKL speed at MAX. i need something REAALLY fast. Guess i'll have to go to after effects |
#285 |
Are you trying to make the finished video go faster, is that what you're saying? I thought you were talking about playback as in preview as i JKL.
When you hit the ceiling you can render to avi and put the rendered event on your timeline, then speed it up once more. You can do this several times. |
