#241 |
Hi all who answered, I eventually burnt to DVD and all looks ok except a small section of footage you can see squares moving as the camera pans. Thanks for all your help Vegas far out weighs Premiere for user ability if you are new to dvd production.
#242 |
Variable bitrate 8,000. I'll burn it and see what it looks like on a TV. Thanks
DVX100A/AT4071a/Vegas/After Effects Dual 2GHz Xeon PC |
#243 |
It's not a question of what folks agree on, I have to chuckle at the opinions I see on this. (nothing meant directed at you, Rob)
Take a SMPTE test pattern on the Vegas timeline. Turn it black and white with either desaturation or the b/w filter. Render to DV. View on external monitor. Which color (original color space, now B/W) shows brightest/contains the most luminance? Green. With DV compression, you need as much information as possible. Green provides this without hitting colors common in daily wear/use. Moreover, due to the way that DV compresses, it's also a pixel and information thing. Vegas upsamples to 4;4;4 on keys, but you still need as much info as possible for the upsample. A good greenscreen free of shadows (wrinkles are ok if no shadows) and good, 3 way lighting is critical. I don't agree with Jackman's method, but it works. It's just extra, unnecessary work. There are several tutorials on this subject on the Sundance site if you care to look. Roughly 50% of our corporate work is done in front of a hard green cyc or a greenscreen. With Vegas in particular, pulling a key is easy on most any semi-consistent color, but green nearly always provides the cleanest key of all due to informational content. Learning to light it right is more important than the color of the screen.
Douglas Spotted Eagle/Spot Author, producer, composer Certified Sony Vegas Trainer http://www.vasst.com |
#244 |
The folks at RSVP seem a little ticked off.
#245 |
Hi,
Tried to run this script on some PAL footage, no great result :-) Every other frame was NTSC 24P format and the other frames PAL format... added some extra ACID feeling to the video. Best regards, Lazze
Sony HDR-CX130,Canon 5DMKII,i7 930@4.0, 12gb memory, 3x SSD + 2x1Tb(stripe), Geforce 480, Dual 24", Win 7 x64 |
#247 |
I should say so. Looks like they can no longer sell Vegas and are promoting a competitor. They were where I got my copy and were strong promoters of Vegas when it was mostly an afterthought.
Nice work Magnus! |
#248 |
Sponsor: JET DV
According to a post by Sony, Canada distribution is still in the process of being worked out.
http://www.dvinfo.net/conf/showthrea...threadid=19425 |
#249 |
Vegas + DVD question.
Hello, I just bought a DVX100A and have decided to make the switch from Premiere to Vegas. I just order Vegas+DVD and it should be here tommorrow, but I have a few questions.
I already have the latest "demo" version of Vegas 4.0e and DVD 1.0 on my PC. I know that the "demo" version of Vegas is actually the complete program and you just need to enter the serial number when given this option. Is the "demo" download of DVD 1.0 the full version including the AC3 encoder also? Do I need to install any thing at all from the original disks or just simply enter the serial numbers for both applications and edit away? Sorry if these seem like dumb questions but I just wanted to make sure now so that I do not run into any problems later. Any advice would be greatly apprectiated. Joe |
#251 |
Expect to have to register online to get an authentication code which will make the apps run beyond a shorter initial period.
Also, expect to register Vegas and DVDA separately. Can't remember if this goes for the Dolby encoder as well. But don't worry - it's all plain sailing. |
#252 |
Your guys rock. Thank you very much for the quick replies.
#253 |
RED Code Chef
Variable bitrate uses at least two numbers, the average bitrate
and the max bitrate, sometimes min as well. I'm assuming 8000 is the max? It's a tad high for average.
Rob Lohman, visuar@iname.com DV Info Wrangler & RED Code Chef Join the DV Challenge | Lady X Search DVinfo.net for quick answers | Buy from the best: DVinfo.net sponsors |
#254 |
Mike Gunter VideoTidbits.com |
#255 |
Equiv. of FCP Audio Sync Tool for the DVX100?
Hi all,
Browsing older posts for the DVX100 I noticed a thread discussing the handling of the camera's approx. two frame sync issue and how Final Cut Pro handles it, which is with a plug-in available on the FCP install disk. Is there the equivilent plug in available for Vegas? If not, what's the best way to sync adjust this cam within the Vegas environment? |
