Vegas Video discussions from 2004 (Q1Q2) - Page 14 at DVinfo.net
Old January 29th, 2004, 09:11 AM   #196
Sponsor: JET DV
One thing you may want to try is to render to a single DV-AVI file first, load that new file on the timeline of a new project, and then render that to whatever format you are wanting.
Edward Troxel is offline
Old January 29th, 2004, 09:58 AM   #197
Glen, I am most recently a 6.5 user, having moved from 5.1 through 6.02. I have no quarrel with the software but I'm aware of some of its shortcomings, perhaps particularly in the ease of colour correction. I have stand-alone assistance in this and other areas thanks to Canopus add-ons, but it's always preferable to have access within the NLE.
David Hurdon
David Hurdon is offline
Old January 29th, 2004, 10:51 AM   #198
Color correction has been an absolute pleasure to work with in Vegas. I even prefer it to Final Cut Pro's color correction tools. Plus with realtime preview (via IEEE) you can "see" the affects of your edits immediatly on an external source (the only way to view your results accuratly).
Ed, you mean to say DVDA doesn't accept mp2's that have separate audio files. It has to be part of the same file? Or is that system stream?
I ask because when I encode from the Vegas timeline I choose the DVDA template which only does video stream. I have to go back and do the audio separately.
Glen Elliott is offline
Old January 29th, 2004, 12:12 PM   #199
Sponsor: JET DV
The "video only" files you are producing from Vegas are MPG2 files that HAVE an audio stream - it's just silent.
Neither Vegas or DVDA accept elementary stream files.
Old January 29th, 2004, 02:59 PM   #200
Best video card/monitor setup?
Hi everyone,
I'm trying to get my home studio set up. I am using Vegas+DVD NLE software and have a single LCD. I have a geforce 3 graphics card.
Here's my question(s):
I would like to(additionaly) hook up a Sony Trinitron 19" to view my video preview in Vegas. Assuming that my card is a dual head, would the Sony be OK for this?
Could anyone suggest a good card to purchase in case the Nvidia won't work?
Thanks for ANY information!
Cameron Stainton is offline
Old January 29th, 2004, 04:05 PM   #201
Please disregard the above post as I have found the answers I was looking for.
CS
Old January 29th, 2004, 04:07 PM   #202
Wow I didn't know that. *scratching my head*............How do YOU know that?! How do you know so much in general?! *lol* Stuff like that isn't in the manual.
Old January 30th, 2004, 02:51 PM   #203
Virtual Dub/Vegas
What video compression should I select in Vitrual Dub for for avi file to be used back in Vegas. Just started using Virtual dub and hve quicly found out the uncompressed RGB avis are huge....
Mark A. Foley is offline
Old January 30th, 2004, 03:18 PM   #204
I'd be willing to bet that there is a frame serve plug-in for Virtual Dub. This would create a stub AVI file which Vegas can use. The advantages of uncompressed, without the disk space.
Joe Sacher is offline
Old January 31st, 2004, 02:04 AM   #205
Lines through clips
I'm using Vegas 4, my captured clips have many lines through them. Can anyone tell me what it is and how can I capture clips without these lines. I was using premiere and had the same problem when I burnt to dvd. Any suggestions welcome appreciation in advance for any answers
Kylie Wilson is offline
Old January 31st, 2004, 06:30 AM   #206
Sponsor: JET DV
WHERE are you seeing the lines? Sounds like you may simply be seeing interlace lines. When you capture standard DV, it is interlaced. When you watch that video on a computer screen, there will be interlace lines present. When you watch that same video on a TV, it will look correct.
Old January 31st, 2004, 12:09 PM   #207
Hawaiian Shirt Mogul
remember your computer monitor is PROGRESSIVE.
for your DVD ?? you might want to look at your project properties to see which method you selected (or didn't select) to de-interlace.
if you are rendering to progressive IMO choose BLEND as deinterlace method.
Don Donatello is offline
Old January 31st, 2004, 01:11 PM   #208
24p MPEG Output Question
I've been experimenting with the DVX100A squeeze mode (simulates a 16:9 anamorphic lens output) and the Vegas 24p support. Here's what's happening:
--24p (2:3, not 2:3:3:2) squeeze mode record
--bring into Vegas with properties=24p widescreen (23.976fps)
--render as .mpg DVD Architect 24p widescreen (23.976, no pulldown)
Results are fine EXCEPT for a 3x3 matrix of little squares that goes flittering around the screen -- looks like a rubic's cube. This is true viewing the .mpg in wmp or on 3rd party software dvd decoders. I haven't burned to dvd yet.
I have a fully registered copy of Vegas and MainConcept, so this shouldn't be some sort of demo flag or something. I've used Vegas to output avi only in the past (which I have burned to dvd just fine) and when I use the regular NTSC DVD output setting to render I don't get the rubic's cube. Is this some sort of marker for DVD Architect? Thanks!
DVX100A/AT4071a/Vegas/After Effects
Dual 2GHz Xeon PC
Stuart Kupinsky is offline
Old February 1st, 2004, 10:16 AM   #209
OT: Chroma Key Materials, Colors and Size
This one's for Chroma Key veterans....
I am looking for recommendations regarding Chroma Key materials - specifically regarding materials, size and color:
Material - Which do you recommend when choosing among (i) paper, (ii) paint, (iii) non-foam cloth, and (iv) foam-backed cloth.
Size - How big of an area is adequate for a full body shot, for example. (I have a guess but I'm trying to get it right on the first setup.)
Color - Blue, Green or Orange?
Your thoughts, experience and recommendations are appreciated!
RL
Robin D. Love is offline
Old February 1st, 2004, 05:45 PM   #210
Optimum ram for XP
Anyone know what the optimum amount of ram for windows xp is? It seems to me that the last I read was 512mb after which there was no appreciable performance gain.
"DOH"!!!
Harry Settle is offline
