Vegas Video discussions from 2004 (Q1Q2) - Page 135 at DVinfo.net
Old June 21st, 2004, 12:22 AM   #2011
john, thanks! that cleared it up for me.
Adi Head is offline
Old June 21st, 2004, 07:04 AM   #2012
Although not every slo-mo sequence is the same/looks the same, I have found at times when the softening effect is produced as Edward mentions, I copy the clip to a new track...add the Convolution Kernel (with the sharpen preset) and set the opacity of the track at 30%.
Mark A. Foley is offline
Old June 21st, 2004, 09:24 AM   #2013
Vegas 4 is faster than 5
when vegas 5 can render as fast as V4, thats when im gonna upgrade...
i started rendering the same project on V5.. tel me 28hrs at 10%
I cancel and throw it back to v4, renders at 17 hours...
on top of that, project loading times are significalty longer (were talkig 14 hours worth of raws being loaded into the Media Pool)
right now, im only using v5 to do stuff i cant do with V4...
anyone else figure this??
Peter Jefferson is offline
Old June 21st, 2004, 09:35 AM   #2014
Sponsor: JET DV
Would need more details to determine why 5 might be that much slower. Were you using a Parent/Child relationship at some point in the project? If yes, that's probably the reason why.
Also, remember that the time is an estimate. The actual time may be much less than the estimate at 10% depending on the details of the project.
Edward Troxel is offline
Old June 21st, 2004, 11:27 AM   #2015
all identical, every frame had to be redrawn..
basically i did the original render.. took 21 hours..
threw the project into v5, took 28 hours
now, im running th same render using a square pixel aspect, and its running 17hours... v4
all identical, no parent child, 3 video tracks 8 audio tracks..
Old June 21st, 2004, 04:10 PM   #2016
Mark, what effect does this have?
Dave Largent is offline
Old June 21st, 2004, 06:53 PM   #2017
PhotoStory2 by Microsoft
Has anyone found any software other than MS that does automatic pans and zooms like PhotoStory 2?
Microsoft has a good solution however it only renders to .wmv files. (It really reduces the workload for photo montages
however rendering is very long.)
I have been looking and I haven't found a solution that does the automatic pans and zooms.
Any help would be appreciated.
Mark
Mark Richman is offline
Old June 21st, 2004, 06:56 PM   #2018
I can do this in Vegas but takes a lot more time
Old June 21st, 2004, 07:16 PM   #2019
Sponsor: JET DV
Take a look at the PBS Wizard in Neon. http://www.vegastrainingandtools.com
Old June 22nd, 2004, 05:17 AM   #2020
I have found adding a sharpen preset with the convolution kernel restores some of the "softening" created by the slo-mo sequence. Dropping the opacity of the track takes some of the bite of the sharpening effect...alll of the settings can/needs to be tweaked for each slo-mo created....
Old June 22nd, 2004, 11:08 AM   #2021
Mark, instead of the filter you use I just apply the sharpness filter to the slow-mo'ed clip at a level of about 400. It saves a step or two. I compared a clip with the sharpness filter and the convolution/opacity process you are using and I can't really distinguish a significant difference so it's worth a try to save yourself a step or two.
Rob Easler is offline
Old June 22nd, 2004, 11:15 AM   #2022
thanks rob....as it would probably save on render time as opacity changes seem to ramp up the render time. If I ever get a break in my editing I may test using just the sharpen filter over the convolution kernel....
Old June 22nd, 2004, 03:26 PM   #2023
Subscribe: how?
Please post a URL to the newsletter subscription form.
-- Update: I found it -- http://www.jetdv.com/tts/
-- Andre
-- (And I corrected it and made it a link - Edward)
Andre Andreev is offline
Old June 22nd, 2004, 08:05 PM   #2024
Sponsor: JET DV
As "a few days" has passed, if you want the proper code, please e-mail me directly.
Old June 23rd, 2004, 11:18 AM   #2025
Rendering an HD 5.1 mpeg file in Vegas
Hi, i'm editing an HD project with footage from the JVC HD10 Camera, I can edit and export just fine but only in stereo.
Is it possible to render an HD mpeg file with 5.1 Surround Sound and then export it back to the camera?
Nuno Madeira Rodrigues is offline
