Vegas Video discussions from 2004 (Q1Q2) - Page 12 at DVinfo.net
Old January 19th, 2004, 11:44 PM   #166
Sponsor: JET DV
Questions? We can handle questions!
Edward Troxel is offline
Old January 20th, 2004, 08:37 AM   #167
Right click on the audio event and change the default so that the pitch changes with lenght. By default it's set to maintain pitch.
Glen Elliott is offline
Old January 20th, 2004, 12:52 PM   #168
I would love to see in Vegas 5 the option of creating our "own shapes" in cookie cutter instead of the presets.....
Mark A. Foley is offline
Old January 20th, 2004, 01:27 PM   #169
Sponsor: JET DV
or at least the ability to vary the shape other than size and position.
Old January 20th, 2004, 01:38 PM   #170
ooooooo yes.......!
Old January 20th, 2004, 04:47 PM   #171
Softspot in Vegas?
I just started playing with the Chromakey in Vegas 4.0+DVD.
Is there a softspot filter? By that I mean center of the screen staying sharp, but going outwards (from the center) the picture gets softer and softer. This will be a great filter for weddings.
I did a search and can't find anything.
Law Tyler is offline
Old January 20th, 2004, 05:05 PM   #172
RED Code Chef
Try the propertional filters under Radial Blur. That should do a lot
like what you want. Otherwise there might be a way by duplicating
your footage to a second track, blurring that footage and merging
the two with a circle alpha picture that changes from fully transparent
in the inner section to fully opaque in the outer rings. This should
be possible to draw with most paint programs.
But see if that filter does your thing. I got some good results
by using the Strong Proportional one and then changing the
strength parameter.
Rob Lohman, visuar@iname.com
Rob Lohman is offline
Old January 20th, 2004, 09:09 PM   #173
Hey THANKS.
Proportional radial blurr works! The keyword there is "proportional". I had tried it w/o it.
Old January 20th, 2004, 10:43 PM   #174
Hawaiian Shirt Mogul
you could duplicate the clip so it's on Video track 1 and 2 ( perfect alignment ) ..
SOLO video track 1 - apply a cookie cutter to the top track ..use either circle or oval on side - adjust size of oval to your liking ... use the feather to soften the edges .. turn OFF SOLO
on track 2 apply gasuuian blur or whatever blur slightly/heavy ...
Don Donatello is offline
Old January 20th, 2004, 10:44 PM   #175
You can also use a cookie cutter with lots of feather, depending on what's beneath, a gradient with a parent or simple blur to the edge if you want to have blacked edges like a lot of wedding vids seem to have, plus myriad other methods of accomplishing this. Problem often is in Vegas, is that there are so darn many ways to do most things.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Douglas Spotted Eagle is offline
Old January 20th, 2004, 10:48 PM   #176
if you use the chroma key FX on the white ( of white/black mask) then you can use the BLUR to soften the edges to your liking .. so it is adjustable RT VS. having to take mask back into photoshop to adjust soft edges ...
Old January 21st, 2004, 10:02 AM   #177
YOu can also use 2 cookie cutters on a generated background to create the bino-mask, or a single with repeat set to 2, turned horizontally. The feathering will create the blur you want, or you could simply drop the blur on as suggested in another post.
Old January 21st, 2004, 10:53 AM   #178
Not seeing the problem there, Spot. :) I find it entertaining on threads like these seeing how many different ways people do something. Of course, occationally I hits me like a brick that I didn't need to do something the hard way. I just didn't see the cool shortcut.
Joe Sacher is offline
Old January 21st, 2004, 01:24 PM   #179
"The 99 page manual is more of a "quick start guide"."
But not, it would seem, a quick fade out guide. :-)
Tor Salomonsen is offline
Old January 21st, 2004, 01:26 PM   #180
Old Boot
Tors, very good . . .
Graham Bernard is offline
