1080 60p camcorder, what project settings ? at DVinfo.net
Old April 2nd, 2009, 03:39 PM   #1
I just ordered a new camcorder that records 1920x1080 60p to mp4 format.
What project settings template should I use ? I didn't see any template with 60p.
https://www.ronchauphoto.com/
Ron Chau is offline   Reply With Quote
Old April 2nd, 2009, 03:57 PM   #2
Hey Ron,
What camera?
All you have to do is:(This will set the project properties to match the file).
1)In preview window, click on project properties button
2)next, click on the icon that looks like a folder(far right if i remember)
3)a browser window will pop up, Then select a file from the poject you are working on.
Michael Hutson is offline   Reply With Quote
Old April 2nd, 2009, 04:06 PM   #3
You might want to convert it first. Vegas' MP4 decoder is not exactly friendly to Sanyo's stuff. It interpreted Sanyo's 1080i as 100fps...
You could try Cineform, possibly, but I have no clue how Sanyo's stuff works with Cineform.
You are talking about the Sanyo VPC-FH1 or the VPC-HD2000, right?
As for if you do get it working, just choose the 1920x1080 24p template and change the framerate to "59.94fps (Double NTSC)".
Old April 2nd, 2009, 04:17 PM   #4
Yes, a Sanyo FH1. Should have it on monday.
If I convert it, convert it to what ?
What if I mix in 1080i footage from a Sony FX7 ?
The end result will be shown on an HDTV through either the camcorder or a Western Digital media player. Speaking of that, what render settings ?
Sorry for the newbie questions. Things were easy with HDV 1080i, but from the reviews, the FH1 at 60p is supposed to be pretty good and I was looking for a small cam for easy on the go shooting.
Old April 9th, 2009, 05:38 PM   #5
Got my project settings to match the 1920x1080 60p footage. As a test, I did nothing to the footage and rendered. No 60p render options.
Tried
mainconcept mp4 60i render played on a media player
bluray disk burn 1920x1080 60i played on blue ray player
hdv m2t 60i played on a media player
All were very disappointing compared to the raw footage played direct from camcorder to hdtv.
What are the EX1 and EX3 users doing ?
Old April 10th, 2009, 02:43 AM   #6
As mentioned above, there is a setting for double NTSC (59.94fps) did that not work? I noticed all the tests you've tried have been interlaced, that probably doesn't help either.
Jon Rule is offline   Reply With Quote
Old April 10th, 2009, 08:36 AM   #7
I used double NTSC for the project settings.
What about renders ? What is the preferred render type and settings ? Mainconcept MP4, Sony AVC, Blueray ?
Old April 10th, 2009, 08:41 AM   #8
Images: 10
Try the trial version of Cineform Neo HD. It's a very well done DI.
Old April 10th, 2009, 01:07 PM   #9
I was just checking on Vegas, as an AVI I can pick double ntsc to render too. It isn't available on main concept, but you can just type in a frame rate, rather than pick one from the drop down. I guess this would apply to any format, although I haven't tried it.
Old April 10th, 2009, 02:02 PM   #10
XviD at 19mbps works very well with 1080p60. And that codec works for the AVI render in Vegas.
Did I also mention it needs less processor power to decode than both AVC and VC-1?
Jack Zhang is offline   Reply
