How can I view? Help needed Please - Page 3 at DVinfo.net
Old April 14th, 2009, 02:02 PM   #31
Originally Posted by Rick Diaz View Post
Just an FYI, you're limited to about 20 minutes of video per disc using this method.
Yes, but still a great option for those without a blueray burner.
https://www.ronchauphoto.com/
Ron Chau is offline   Reply With Quote
Old April 14th, 2009, 02:48 PM   #32
No doubt, just wanted to note the limitation.
Rick Diaz is offline   Reply With Quote
Old April 14th, 2009, 03:29 PM   #33
Originally Posted by Marcus Martell View Post
Just done my first test on a FULL HD Samsung,here is my first impression:
I 've rendered a clip in Mpg2 hdv1080 50 i template:logos a little bit with shaky borders, but an overall image good (not excellent).
Then i rendered in WM9:logos were perfect but the pan camera moves are shaky.
Suggestions?Maybe i'm messing up with the settings.
Thank u guys!
Thank You Seth for a direct answer, I appreciate that!
Marcus, I used the WM9 default template with excellent playback in logos and all other aspects incuding edits and all. I will experiment a little with Seth's suggestions and see what happens.
All in all this little unit kicks a$$, it even decodes Ipod tunes so you can blast your music through your home theater nicely while simultaneously watching something else and does a great job with my photos even though I did not get it for any reason other than my HD Video.
www.socalt.com
Tim Cee is offline   Reply With Quote
Old April 24th, 2009, 06:38 PM   #34
So guys how's going with your wdhdtv?
Any trick to teach?
I can't find how to set the loop option...
thx
Old April 28th, 2009, 08:49 PM   #35
Any trick to teach?
thx
The loop option is in the settings, it is the world wide recognized icon of the loop.
Not many tips I can share as this thing is incredibly easy. It is amazing that such a low price investment has solved so many of my HDV viewing woes.
I applaud WD for this product. In a time with more technology than knowledge to use it, the WDTV solves problems with such simplicity.
www.socalt.com
