Best quality for Youtube at DVinfo.net
Old March 24th, 2009, 12:38 PM   #1
Hi All,
Will someone please tell me as how can I achieve the best quality output for youtube and web base?
Matthew
Canon XHA1, Brevis 35mm, Manfrotto 028,501,Vegas Pro 10e
Matthew Amirkhani is offline   Reply With Quote
Old March 24th, 2009, 12:50 PM   #2
For SDV or HDV?
www.nostalgicFrames.com
Dror Levi is offline   Reply With Quote
Old March 24th, 2009, 01:19 PM   #3
Check out the Best Render for Youtube HD in Vegas thread for some ideas.
Douglas Spotted Eagle mentions a tutorial on the VASST site that should help too.
Old March 24th, 2009, 04:13 PM   #4
you need to follow several basic rules.
1) resize your video to final width and height.
Youtube and other are displaying video almost always the same, so there is no need to provide a big sized video. It will be resized anyway, with no control over that step, since it takes place in their server. And the upload process will go faster and you will get more bytes to give to quality versus size. Make an uncompressed export of your movie and resize with virtualdub (on PC) for example.
2) Apply de-noising filter. Noise could not be visible while still present. De-noising video allows to get better compression.
3) Submit/upload file encoded with the closest codec that is in use on the website. Each codec has it own tricks to reduce the bandwith, but when they add, the final result could be very bad. Try to find which codec they use and encode with the same, this will allow to see where problems can occur.
4) Apply filter for contrast and details. Most high compression codec tends to reduce contrast and add fuzziness.
Old March 24th, 2009, 04:15 PM   #5
How to Make YouTube Videos Look Great
Old March 24th, 2009, 06:00 PM   #6
What about Vimeo?
thz
Old March 25th, 2009, 12:15 PM   #7
I actually recommend 1280 x 720 @ 5mb~ now adays... in any basic codec/format.
Both Youtube and Vimeo will resize to their idea of "HD" which is the best quality you're going to get out of them.
Then once it's uploaded, Youtube and Vimeo both render out 2 sizes of video, one standard/low quality, the other being the high quality at a decent bitrate. People simply click the HD button to see it.
And Vimeo will allow registered users to download the original file you uploaded off the site (Which is also cool).
So yea, I'd say stick with 720p @ 5mb/s bitrate for either one.
If you are using HD/HDV that is...
Joe Busch is offline   Reply With Quote
Old March 25th, 2009, 12:57 PM   #8
Originally Posted by Marcus Martell View Post
What about Vimeo?
Exporting with Vegas for Vimeo HD
Old May 5th, 2009, 02:43 AM   #9
Originally Posted by Giroud Francois View Post
Now that is a great link! Thanks!
Robb Swiatek is offline   Reply
