need help setting up production monitor at DVinfo.net
Old March 18th, 2009, 08:53 PM   #1
i am very new to video editing...i have never used a production monitor and reading thru this forum i knew i need one, due to a tight budget ... i bought a used older JVC BM-1310SU off ebay... i dont see any DVI or VGA inputs on this monitor ... maybe cause its a older model .. my question is how am i going to connect my computer with this so i can use it as a second monitor for display on Vegas .. most of the threads here talk about connecting it thru DVI or VGA on the video card but i dont have those options i guess ... what do i do?
Canon XL2, 20X zoom and 3X wide-angle, , Sony Wireless UHFs UWP-C1 and UWP-C2 , Manfrotto 503 head on 351 tripod , Glidecam 4000 Pro w/Glidecam Smooth Shooter
Wajahat Abbasi is offline   Reply With Quote
Old March 18th, 2009, 11:35 PM   #2
You could connect FW to your XL2, and then take analogue video from the XL2 to the monitor. Only problem is that it ties up your XL2 as an AV interface when it could be used for shooting.
Richard
Richard Hunter is offline   Reply With Quote
Old March 19th, 2009, 12:34 AM   #3
Taking a feed off your video card will not display the true colours of your video anyway, so for colour correction work that's a non-starter.
You will need to invest in a digital to analogue converter. I use the DAC-200 but there is a wide choice to suit all budgets. That will allow you to take a signal from your PC (i.e. Vegas), route it via a firewire cable through the converter and then, depending on the connections you have (RCA or, in my case, BNC), connect that to the monitor.
In effect, it's exactly what Richard is suggesting (using the XL2 as the digital to analogue converter) but without tying up the camera.
Of course, my way introduces an element of cost . . .
Ian Stark is offline   Reply
