recording multiple audio sources in vegas 8.1 at DVinfo.net
Old March 9th, 2009, 10:27 PM   #1
Hey all,
I'm working on a project where I need to have 4 - 8 tracks of audio recorded at the same time as the video.
does vegas have this ability? as an audio capture interface I'm using a Presonus FP10
--------------------my story----------------------
Media Study student at S.U.N.Y. Buffalo
Documentary / Real Time Graphics concentrations
Scott Blajszczak is offline   Reply With Quote
Old March 9th, 2009, 11:57 PM   #2
Originally Posted by Scott Blajszczak View Post
Hey all,
I'm 99% sure Vegas does not have this ability. You probably need Sound Forge. And at only $200, it is worth it just for the noise reduction plugin (which is why I purchased it!). The term is "ASIO driver support" which usually means supports hardware that can feed multiple channels simultaneously. As long as your hardware is on the list of apps that SF can talk to, then you are in business.
Reference this page: http://www.sonycreativesoftware.com/soundforge/record
Jason Robinson is offline   Reply With Quote
Old March 10th, 2009, 07:31 AM   #3
Sponsor: JET DV
Yes, Vegas can do this. In fact, that's what Vegas was ORIGINALLY designed to do.
You will need a sound card with multiple inputs. Then you can assign the multiple inputs to separate tracks. Finally you arm the tracks for recording, hit record, and it will record the audio direct to the timeline.
Just try it out! I think you'll be pleasantly surprised.
Old March 10th, 2009, 03:03 PM   #4
WEll look at that. Apparently it does have ASIO support. I should have known it would, since as Ed mentioned, it was first an audio app, then video.
Old March 16th, 2009, 01:27 AM   #5
well, i'm going to be running 4 channels of audio into a fp10
PreSonus
and then running the fp10 via firewire into my laptop.
does that solve my problem?
Old March 16th, 2009, 07:37 AM   #6
That should work fine. I believe the PreSonus outputs descrete channels from each input. I have a little Alesis FW mixer that I use to capture up to 8 channels into Vegas with no problem. I don't know if you'll be able to get 24-bit at 96K for 10 channels or if you'll have to drop the sample rate to 48K.
Garrett
Garrett Low is offline   Reply
