Best settings to render in PAL... at DVinfo.net
Old January 26th, 2009, 10:22 AM   #1
Wich are the best setting to select from the beginning to have best quality in PAL:
HD
Sd mpg2
AVI DV
thx!MM
Old January 26th, 2009, 10:37 AM   #2
Sponsor: JET DV
What's the source?
Old January 28th, 2009, 02:33 AM   #3
Just make sure the preferences in Vegas as well as DVDA are the same;
MPEG2
PAL,
720 x 576i @ 25fps
8 Mbps VBR lower field first
Audio at 224 Kbps, 48Khz Layer 2
Burn onto +R discs, as these are recognised by more PAL players.
The critical thing is what you are rendering from... the best result will be if the vision was shot at 25fps PAL in DV (or as an .AVI file). If its NTSC at 29.97 then there will be an image degredation.
However, if you use the above recipe (or use the DVD PAL option in the render menu) the disc will play in 99% of players in the PAL world.
HTH
Ben
Last edited by Ben Longden; January 28th, 2009 at 02:41 AM. Reason: Its 43 degrees outside... okay... (degrees celcius)
Ben Longden is offline   Reply With Quote
Old January 28th, 2009, 05:05 AM   #4
The source is HDV footage shot with hvrz1e...
and what about it's SD footage?
I wanna make sure everything i do is correct!
thx
MM
Old January 29th, 2009, 09:16 PM   #5
Easy.
Just make sure the preferences are set before you start, then Import the vision onto the timeline as usual.
Vegas will automatically downconvert the HD to SD (because you asked it to in the preferences) and then edit it as normal.
To reduce the overall render time (unless you have a quad core), make the first render to a PAL compliant .avi file, which is a sanity saver if you have a dozen lines or so with colour correction, unsharp mask etc. Then render the PAL .avi file to MPEG2
Just make sure that DVDA has the same preferences, especially PAL, or you will get a horrible result.
Doing this works just fine for me...
Ben
