Scene detection? at DVinfo.net
Old January 24th, 2009, 02:30 PM   #1
Scene detection?
I'm using Sony Vegas 7.0e to capture DV files (downconverted from HDV) from XHA1 and getting 1 big file instead of multiple files (usually generated from rec-stop scene detection). Is there any setting in the camcorder or Sony Vegas I should adjust to make the scene detection works properly? Thanks in advance!
Ian Lim is offline   Reply With Quote
Old January 24th, 2009, 07:23 PM   #2
This should be moved the Vegas list. The A1 doesn't really have anything to do with this.
I don't use Vegas so I cannot help you with this.
Old January 24th, 2009, 07:31 PM   #3
Hi Ian. Vegas has 2 separate capture applications, one for HDV and one for DV. Try checking the "Enable HDV Scene Detection" and "Enable DV Scene Detection" boxes in the preferences for the 2 capture apps, and see if it helps.
Richard
Richard Hunter is offline   Reply With Quote
Old January 24th, 2009, 08:12 PM   #4
I tried this on my A1 and Vegas 7.? to see if maybe the down conversion process in the camera was interfering with the scene detection process, but Sony detected the three scenes downcoverted from HDV 60i to DV without a hitch. As the previuos poster said, have you gone to Preferences>Capture>Scene Detection to verify it's selected?
Steve Rusk is offline   Reply With Quote
Old January 25th, 2009, 07:05 AM   #5
Sponsor: JET DV
Another quick question: Is the CLOCK SET on the camera? If the clock was not set when the tape was recorded, scene detection will not work as it looks for jumps in the date/time code.
Old January 25th, 2009, 12:03 PM   #6
Guys, thanks for the tips! Will try all of your suggestions few days later and will post the result. Thanks again!
