Windows 7 Beta and Vegas Pro at DVinfo.net
Old January 14th, 2009, 09:21 PM   #1
Anyone try this combo yet? My friend installed Windows 7 Beta and says his machine is ALOT faster than just running XP64bit. Just imagine vegas pro on it!!!
Chris Wysocki is offline   Reply With Quote
Old January 15th, 2009, 05:08 AM   #2
I can't do a comparison to XP64. But I've just built a core i7 system with Vista64 and Win7 64 bit installed.
Running a couple of render tests using Vegas 8.1....
The dual core render test (from VASST I think) - rendering to DVDA PAL widescreen template took 2:52 on Vista and 2:57 on WIn 7
The hdvrendertest (on the forums at sonycreativesoftware) rendering to HD1080-60i took 1:01 on both systems.
Obviously, as Win 7 is still in beta these times could be slightly higher then the eventual final product.
Ian
Ian Briscoe is offline   Reply With Quote
Old January 16th, 2009, 11:36 AM   #3
I'm running the 64-bit Windows 7 Beta on my Core 2 Duo T5600 Sony Vaio laptop. I have Vegas 8.1 64-bit installed.
It works. I could probably use more RAM - it only has 1 GB now. Seems to be glitch-free so far, but I certainly haven't run render tests or put it through its paces.
Mark Holmes
www.daisy3pictures.com
Mark Holmes is offline   Reply With Quote
Old January 16th, 2009, 12:29 PM   #4
I got the beta iso as well, but have yet to work up the courage to wipe my may render system (or monkey with the partitions) so that I could try it. May be after I'm done with all the edits in my post-production queue.
Jason Robinson is offline   Reply With Quote
Old January 17th, 2009, 03:20 PM   #5
I am tempted to try this as well, but I am unsure how long the BETA version lasts - if it expires during a project, that would be trouble...
David Delaney is offline   Reply With Quote
Old January 17th, 2009, 03:46 PM   #6
August 2009
Pete Bauer
Old January 17th, 2009, 03:48 PM   #7
The Beta stops working August 1.
Ian
