#31 |
Hmm, is there any loss of detail by using this deinterlacing method? Because i'm pretty sure that there has to be SOME loss because it's filling in some data that isn't there...
#32 |
Excaliber ?
Edward,
I checked out Excalibur and Liked it!! I downloaded it and it is all in a folder in my documents, How do I get into vegas pro 8c? do I need to go back and download again to a different location? thanks
DATS ALL FOLKS Dale W. Guthormsen |
#33 | |
I actually found my 50% slow motion is sharper/more detailed then the plain de-interlaced footage which is interesting. Native 60p footage is definitely better, but this is a really good alternative because a.) You would only be shooting 60p if it was to get better slow motion, final render will still be 30p. b.) There aren't really any consumer/prosumer cameras that shoot 1080p60 anyways |
#34 | |
Digital camera | TOP : VPC-FH1 | SANYO Digital camera | TOP : VPC-HD2000 | SANYO |
#35 | |
I could say my FX7 shot 2k if I just up-rezzed it a bit right? -_- |
#36 | |
Richard |
#37 |
HV10 had a 1920 x 1080 sensor too...
What's your point? |
#38 |
Sponsor: JET DV
Dale, the download is an installer. After downloading, run that program and Excalibur will install. After installing, in Vegas Pro 8 go to View - Extensions and you will find it there.
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
#39 |
Sorry, maybe I just don't get your point Joe. Are you saying the image from these cams is like 480 lines uprezzed to 1080? I haven't been able to find any sample footage from the HD2000 so far. What is this opinion based on?
Richard |
#40 |
I'm saying that the pixel density of the sensor doesn't really matter. You get crappy footage out of crappy cameras.
#41 |
Edward,
I reinstalled excaliber, It went through fine but the folder with all the software ends up in the documents section. should I send it to programs?? I checked extensions in view edit and tools, no extensions. thank you for the help.
#42 |
Sponsor: JET DV
It installs in {my documents}/Vegas Application Extensions so that sounds correct. In order to see Excalibur 6, you MUST be running Vegas Pro 8.0a or newer. It will not appear if you're running the original 8.0 version but will if you have 8.0a, 8.0b, 8.0c, or 8.1. Since you're running 8.0c, it should be appearing fine.
#43 |
Edward,
thanks for the time!!! We had recently put clean installs of xp on the computers and this computer had not been upgraded as I do not usually use it for vegas!! I will now put into the vista 64 system. thanks again!! now to get familiar with it!!
#44 | |
put another way....does using Project settings Interpolate Fields to conform the 60i effect the other 30p on the same timeline? Last edited by Jonas Marlowe; October 6th, 2009 at 11:02 AM. |
