Chapters too close warning - what does this mean overall? at DVinfo.net
Old November 30th, 2008, 06:47 PM   #1
I don't know why but I am getting 'chapters too close' even though my chapters are about 1 minute to 3 minutes apart. Is this going to affect the viewing of the DVD? I haven't set chapters in DVD arch - I did put them into Vegas when I was rendering, and when I go to prepare I get this error. Any ideas?
David Delaney is offline   Reply With Quote
Old December 1st, 2008, 01:29 AM   #2
It would suggest your chapter markers are less than 1 minute apart. Are you sure you don't have one too close? Open the media in DVD A timeline, you should be able to zoom in and find the offending marker.
Douglas Spotted Eagle/Spot
Author, producer, composer
Certified Sony Vegas Trainer
http://www.vasst.com
Old December 1st, 2008, 03:33 AM   #3
Old Boot
Huh! I didn't know there was a minimum for Chapter Makers. So I read the online help for DVDA5 and it says that:"Chapter Markers must be one second apart".
And in another note it says "You can create markers that are less than one second apart by importing markers or by moving a movie's in/out points too close to a marker".
On this basis I would be double checking to see if markers have gotten to less than 1 second spacing. And this might have occurred at your Vegas timeline level OR you have the ins and outs too "tight" OR you have 2 markers that appear as ONE marker! - Having read the Help, most likely you have 2 or markers appearing as one - yeah? It would be unlikely you would "purposefully" force for a Chapter in the less than 1 range? Would you?
Thanks for bringing this to my attention - at least it forced me to read the online help.
Grazie
Old December 1st, 2008, 08:57 AM   #4
I had this happen to me once. Because a MPEG I rendered in Vegas had a chapter point just inside the render region, and because DVDA puts a chapter at the very start of the timeline for a media.
Try deleting the chapter point at the beginning of the media and you will probably find another chapter point "hidden" under it at either the same point, or nearly the same point.
Jason Robinson is offline   Reply With Quote
Old December 1st, 2008, 05:22 PM   #5
Are there any adverse effects to this? I don't care about the warning as long as it doesn't affect my outputed DVD.
Old December 1st, 2008, 05:45 PM   #6
I've gotten that warning a few times even though the markers are more than 1 second apart. On the rare times it is 1 second or slightly less the warning shows but there hasn't been any problem burning the DVD nir any problem with it playing.
Don
Old December 1st, 2008, 06:08 PM   #7
it wasn't a warning. it was an error. DVDA will not proceed with an error. So I jsut went back and moved one of the chapters a few seconds forwards on the time line. problem solved.
Old December 1st, 2008, 07:16 PM   #8
It was just a warning for me - so I am going to just burn and hope for the best.
